Sorry for little OT, but this is so little question, so I won't open new thread... If I use "automatic radio channel search" etc, it brings 20 best channels, but if MY
favourite channels are in in memory places e.x 7, 14 and 17, is there way how can I move them to memory places e.x 1,2 and 3, so it would be much much more easier surf between channels. Thanks
Auto store should fill preset memory locations starting from number one. I assume you have all 20 (almost at least) stored but your favourites aren't where you would want them to be.
I guess you just have to move them manually. Move the first station to one of the last you don't care, then the one you want to the first. The second to the empty location and so on.
You can store the station manually (select e.g. from an existing preset first), next enter the preset stations menu, scroll to the location you want, press and hold the selection wheel.
Thanks Diesel Benz, that worked Although I have new problem for you to solve! When I am listening radio, and when I pick new channel from the list, sound is very very good and crystal clear, but after listening something like half minute (although it could take sometimes 10 minutes when you start engine, weird?), volume level drops a little and you can hear sughing in the background (dunno if this right word). Difference is huge, but what doens't make sense is that, when you change to different radio station, and immediately go back station what you were listening, quality is very very good, but after about 30 seconds quality drops. I have tried it with different speeds, and driven it in the same neighbourhoods where all other cars I have driven pick good quality all the time I have tried with and without frequency fix but no difference.
Sounds strange. Do you have Sound system in the car? Perhaps your sound system Logic7 settings are not suitable, try putting everything to basics, Logic7 off and what ever else can be disabled.
Yes I have sound system. I tried different settings but no difference. Anyone have clue what's wrong or is this just normal?
So have you been able to do this yet? If so, how much?
yes, we have had the video unlock piece out since fall for w221 and w216. Its really nice, unlocks DVD for both systems where the parking brake has to be set to watch video and systems that allow video under 3km/h. The unit also unlocks Nav functions that normally only work when you are stopped. Installation is very easy, literally a 5 minute job using all factory connectors, no cutting and splicing.
pm me if you have any more questions.
I have a question for you: For european specs cars, the video lock for DVD, TV or Video Aux, works when you run more than 3KM/H (person step) doesn´t matter the parking brake position. Can you confirm me, if your modules will work on European specs cars. If yes, I´m interested to buy several units.
THX
THX
Since were in the US I havent been able to test the module on a euro spec car but I can tell you that the module does filter the speed data so in that respect it *should* work.
