Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 04-02-2001, 12:39 PM   #1 (permalink)
Date registered: Dec 1998
18' wheels rubbing (w/ 275 width tires)
Just installed a set of Brabus 18" MonoV's. Reqally happy, however, there is a rubbing sound eminating from the right rear wheel over bumps at highway speed with suspension in soft, lux mode. What is the common method for "rolling" the fender lip on the inside so as to avoid this problem. someone suggested taking an airsaw and cutting a 1/4" off the inside - needless to say I got out of there really quick. There has to be a better way or else they're coming off in favor of something else. How do the AMG's do it - same size tire.<br>
<br>
Thanks!
Old 04-02-2001, 01:26 PM   #2 (permalink)
Rubbing...
Your M-B dealer can roll the fenders for you. They charge about $60 per fender for a C-class. I assume the price is similar for the S. Other shops can also do it if your dealer won't do it or quotes you a rediculous price.<br>
<br>
You were right to run from the guy that suggested cutting off the fender lip with a saw. It would eliminate the rubbing, but that lip has welds that are part of the structural rigidity of the fender. Removing it could cause rattles, rust, and inferior crash protection.
Old 04-04-2001, 04:50 PM   #3 (permalink)
Rolling fenders
Thanks a lot Brian for the advice. I'll give the dealer a call.
Old 07-06-2003, 12:16 AM   #4 (permalink)
Date registered: Jun 2003
Vehicle: s500- 300td
Rolling the fenders
I just added 20" Monoblock VI to my s500. I drove today for the first time and the right back wheel hit the fender also. I will look into calling the dealer to see the cost. Brabus charges $400.00 to do so.
bigbodi is offline   Reply With Quote
Old 07-10-2003, 05:35 PM   #5 (permalink)
another opinion
Before you go to the dealer. Brabus wheels come with extenders in the back. On my wheels there were 5mm on each wheel. I took those out and did the trick.
Old 08-04-2003, 07:31 PM   #6 (permalink)
Iwan's Avatar
Vehicle: CLS 55...
Try this
I have 19" AMG wheels on my S-Class with 275 rubber, and the rear tires rub the inner fender a bit. My wheel shop said its not the fender itself that it is rubbing but actually a section of the inner plastic fender cover. if you look closely where the rear bumper starts to meet the wheel well, there is a section of plastic that extends a bit outwards, this section was sanded off and no more rubbing. No modification were made to the fender itself. Hope this helps.
___________________
'05 CLS 55
'85 280 GE (a classic !)
'07 LR3 TDV6 HSE
'07 BMW R 1200 GS
Iwan is offline   Reply With Quote
Old 08-04-2003, 09:36 PM   #7 (permalink)
thank you, I will try that and I also took out the wheel extenders that helped. ...
