Hello everyone ,
I am going to start another ABC valve block thread lol. I know there is already many many threads about it and i have searched them all.
So here is my issue
I recently rebuild my front valve block because the car would sag after sitting for a bit especially on a hot day. I did not replace the white teflon rings because the kit that i bought : ABC plumbing block plumbing seal o ring kit | eBay
The kit came with only black rubber seals and i was not sure if its a good idea of changing the teflon rings to the black rubber ring, so i only changed the black rubber ones.
My question is do you guys that if i change the teflon rings with the black rubber rings that i still have from the first kit will solve my problem, or should i just go ahead and buy the teflon set from Britain.
Has anyone had success with changing the teflon rings to rubber ring , the ones from the first link above.
I have done a filter change, but not a flush.
I am doing a flush tomorrow , due to a bursted line, so i have to put in new fluid anyways.
Any feedback is appreciated.
BEST SOLUTION FOR YOUR ABC VALVE BLOCK / NO PROBLEMATIC UNIVERSAL BLACK RUBBER SQUARE RINGS WHICH ARE NOT SUPPORTING RINGS IN FACT!
THIS ARE PTFE TEFLON RINGS MADE BY 0,01MM ACCURACY TO FIT ABC VALVE BLOCK BORING. PLEASE CHECK PHOTOS HOW ACCURATE THEY ARE!
WILL PROVIDE BEST PERFORMANCE TOGETHER WITH SEAL KIT ! NO COMPROMISES
THESE WAS DEVELOPED BY CAR HYDRAULIC SPECIALIST AND CUSTOM MADE BECAUSE FITTING THE UNIVERSAL RUBBER SQUARE CUT RINGS SHARED AS EXCHANGE ON THE INTERNET WAS PROBLEMATIC AND NOT IDEAL DIMENSIONS.
IF YOU WANT BEST PERFORMANCE FROM YOUR abc VALVE FIT TEFLON SUPPORTING RINGS/ TESTED AND WORKING LIKE A CHARM FOR MANY YEARS BEFORE RELEASING ON EBAY.
CHECK OTHER LISTING FOR O-RING SEAL KIT.
I'm surprised you didn't fit the square cut rings in the Kit you got, they will work in a scrupulously clean un marked block, but teflon rings are better :wink
just to clarify:
The white Teflon rings do nothing to seal hydraulically, they are there to make sure the O-rings do not deform.
If they are in good shape, just replacing the O-rings is ok.
One of the white teflon rings was broken on a solenoid in my case. I simply put three of the same size o-rings on that part of the solenoid and reinstalled. Everything got a bit of CHF-11s fluid to lubricate prior to reassembly. That one went back in as easily as the rest, and so far, no leaks.
(Except Ford Type F ATF or CVT applications). Mopar® ATF +4® (9602) and all other highly friction modified ATF's. Honda® Genuine ATF. Mopar® ATF + 3® (7176). - Will not alter the crucial sulphur balance in your transmission fluid.
Are you recommending this Transmission additive to be mixed with fresh MB/pentosin ABC oil? I'm curious why.
I have to say I'm Always bit Skeptical when it comes to additives… especially with factory recommended fluids. Snake oil syndrome I guess. But if there is a merit to this one specifically, please explain. Your experience is much more valuable than any prejudice I might have towards "snake oil".
Stuff like Dr Tranny's Instant Shudder Fix etc etc etc is Snake Oil, and I'm old skool like you regarding Snake Oils
Lubegard is exactly that, (a Lubricant Guard), it helps the existing Oil.
It is very good stuff, used it for years both in Transmissions and also ABC / PAS Systems
It will mix perfectly with the Pentosin and does help to keep Valves etc clean and free, helps seals stay soft and well lubed, over and above the properties / additives already in the Pentosin
HTH
