Help! Accelerator pedal
Hello
Recently, after replacing the spark plugs of the engine and its relay, the car was just taken out of the workshop, "EPC Visit Workshop" appears, but when I turn the car off and on, this fault disappears, and soon after driving Appears again.
I have noticed that it is on descending slopes when you lift the accelerator pedal.
I have analyzed with Auto-com OBD2 and it shows me "P1234 Pedal value sensor 2", analyzing values, sensor 1 and sensor 2 are correct, 100% pedal fully up and raised 0%. If I drive until the fault appears, I connect the Autocom and scan, with the pedal raised puts sensor 1 - 0% and sensor 2 - 9% !!! How is this possible?
I have tried with another accelerator pedal and it is not solved, I have reviewed the installation and it is not solved
Any ideas?
Thank you very much!
Joseph.
Hello
Any ideas?
Joseph.
