Hello all,
I needed some help with my 2002 s430. I did some work on it (thermostat, radiator fan, filters, tranny mount) and now it won't start. Lights turn on, remotes both lock and unlock, power in dash and radio but does not start and won't get out of park. I have already gone through the w220 enc and it did not help.
Here is what I have done so far:
Replaced starter relay (L) and other ones (N) and (K).
Visual check of fuses ok.
rear junction box had 1 40a fuse blown, replaced whole part
passenger foot well junction box checked and no blown fuses
Battery had a bad cell, replaced with brand new gel battery
both keyes tried to start, no luck - both spin all the way.
I doubt it is the starter as it was perfectly fine before, doubt it's the shift column because never had an issue before, doubt it is EIS as I can turn the keyes all the way.
Any suggestions other than "take it to dealer or rep". Thank you.
