Hello Benz Collegues,
My case:
I am the proud owner of a S500.
Recently replaced the shocks front and back because of the much talked about air leakage. For a few weeks no problems with the struts. This week we came back to the car and we saw the back was down.
The front works fine, car pumps itself up, even to the higher level if requested.
Back stays low, not even an attempt to lift itself.
No airleakage, no hissing, airpump in the front only works when the front needs lifting.
Tried draining al the schocks from air, no response (front does pump up again after drainage)
Took off battery pole, no effect.
Jacked the back of the car a bit up (maybe to initiate level-device) no effect.
Would really appriciate tips/advice!
Kind regards from the Caribbean.
Jarno
My case:
Jarno
