Airmatic Strut set screw removal heat method
20K views 14 replies 12 participants last post by  MercedesBenzOva
For those of you that need to loosen the two grub screws which secure the Airmatic strut to the Spring Control Arm for any reason, here is how I did mine.
In my case, needing to remove the Spring Control Arms to have the Sway Bar ball joints replaced, I had to remove the Airmatic strut from it. My first attempt to loosen the set screws resulted in a broken hex wrench and frustration.
Upon further research in our forum, it became obvious that using heat was the most successful method. (wallyp broke some bits too post 3)
Thanks to Eric’s post 4, he suggested using a hair dryer to soften the Locktite but the one I have is too big to get in there and not much heat either. I purchased a miniature butane torch which then made this job painless.
This torch provided a nice small sharp flame that is easily controlled as to not cause any collateral damage.
The Loctite was no longer a factor and the screws just backed out with little resistance against 20Nm installation torque.
Complete success
Removing the set screws became the easiest part of the job. This turned out to be a tremendous confidence builder especially after reading all the horror stories of the broken hex wrenches and stripped set screws that had to be drilled out. (The messes we get ourselves into sometimes!)
Hope this helps,
Bob
Thanks for the method!
This year I had the same problem. After breaking some 5 hex wrenches my mechanic welded hex wrench to screw and finally was able to get it out. I don't know where did he got replacement screw. But the new screw was oiled and he said that next time it will be easier to unscrew.
#4 ·
I did the same thing my 9 year old daughter was helping me. I used a small torch as well and left the heat on for seconds, it backed right out. I was putting new Arnotts on so I have no worries about the set screw.
I actually made a necklace out of the set screw for my daughter just because of the pain it was to get out. My daughter thought it was funny. She did learn some new words. I dropped it into a jewelers glass vile and mounted it on a chain. Was going to drill it but never got around to it. It started as a joke I said if this screw comes out I will make you a necklace out of it so you will remember how much fun it is to change struts on a S-Class
Let's hope that it doesn't unscrew before you want it to! Mercedes apparently was concerned about the screw loosening in service.
Just buy some blue lock-tite and apply it you will be good to go
#5 ·
Your pictures are very helpful. I have the exact same torch. The front of the strut has the extra thing (controller?) on the front. Looks like you just pull down to unplug to make room for the torch flame. Is there any trick to getting that plastic piece off and away from the front set screw?
#6 ·
Hello Skylaw,
I think the torch wizardry posted by mercy-me should be added to the Encyclopedia. MB applies the blue thread-lock for reason, but it causes too much pain for too many. I had this with one of the hex screws when I removed the shifter box, the most frustrating experience of all my DIY jobs.
Best
George
#7 ·
I don't recall seeing this thread in the Encyclopedia, so if indeed it's not there, I'd also suggest its addition.
owns 2003 Mercedes-Benz S600
#8 ·
I will look into it today......
#10 ·
Its encyclopedia'ed. Chapt 1 post 3 of 17 close to bottom. Actually done by Skylaw in 2015. I thought I had seen it in there but wasnt certain.
#9 ·
Thanks, Ex-Fed!
One other thing I should mention about this little tip. When I tried it, it was with the regular ol' propane torch that you buy at the Home Depot for soldering copper plumbing pipes. I actually had to hold the hottest part of the flame directly on that little bolt for about 60 seconds to get the Loctite to loosen. I mention this because some have mentioned that maybe 5 seconds will do the trick. \
Note that I kept the flame pretty small, where the bluest "inner core" part of the flame was maybe 1/2 to 3/4 of an inch long. It looked a lot like Bob's butane-torch flame in the pics.
So, it took 60 seconds per bolt on my springs instead of 5 seconds. But, this tip *does* work.
Bob, thanks for posting this.
#12 ·
That little plastic piece is held in place with a set screw on the bottom of that cylinder. The hole the screw goes into is seen just above the orange grommet in the image you posted.
#13 ·
Smh I screwed the pooch on this one one of the hex's stripped ....attempting to drill it out ...not looking good for the home team lol.. if any one has drilled it out what kind of bit did you use and yes I have taken that cap off over the screw 🤔🤔
2669775
#14 ·
Moderator Request ....
Welcome to Benzworld.
Please update your user CP info....
click on your icon----> click on Account Settings---->
go to Account Details----> add vehicle details---->
ADD your make and model YEAR ---->
Add your Territorial Location ---->
click save
Read ALL of our stickies before posting, especially the New Guy Sticky.
