Perhaps some one can suggest what I try next...I'm stuck and I have searched threads to best of my ability.
Red SRS Light ON: Got it read as CODE 1859 Front drivers Air bag. Immeadiately suspected a fault on "clock spiral" behind steering wheel. Stripped it down and replaced clock spiral with new, from those nice Stealers ÂŁ100 lighter. Got diagnostics dude back to read and delete code from SRS Module memory. Failure! (UPDATE: the Diagnostics SNAPON unit could read but NOT delete code...@ the time i didn't know this...read on)
Diagnostics unit can see all the other air bag in the car, see occupancy sensors and pre-tensioners, all labelled on the LCD display as "found and okay." But it could not read or see front drivers airbag which was just blank, no text, and continued to display 1859 code!!!! :surrender:
Also highlighted a low voltage warning at SRS module. Where does this live? (UPDATE its behind the ashtray and command you can get to it by removing the ashtray, facia and command unit, remeber to DISCONNECT BATTERY before even looking at the SRS module its bolted to the cars chasis with three bolts. one has an earth stud which was rusty as hell!) If I disconnect the battery will be be safe to clean all the connectors? if so can anyone can tell me where it lives?
What i intend to try next...
I tested the continuity through the old clock spiral and found no faults!!!!
I checked 1859 out as a Menz OBD2 DTC and it offered this (P1859 Supply voltage < 8.5 V or > 17 V) Red herring or related to the problem I don't know??? (UPDATE: a low battery or loose battery connection probably threw up the SRS code in the first place and once it was logged in its memory it failed to initiate the SRS everytime the car was started, the code has to be deleted and removed! using STAR/DAS)
I saw a warning and recall notice that a faulty multiplug can be an issue and a new harness can be spliced in to replace it, this is further behind the steering wheel and mounted on the bulkhead.
Can I test the airbag without setting it off? to see if it has the right resistance level to be seen by the SRS module? (UPDATE SCAN DAS suggests a value of 0.8-2.5ohm if i remember properly)
Any suggestions much appreciated.
Andrew (MOT 9Days to retest and ticking.)
In the Uk apparantly SRS is an MOT failure point
still it needs fixing anyway. If you want to offer me sympathy i had to replace both lower track control arms....that hurt a lot....it has taken me all day! Particularly drilling out and retapping the stuck grub screw in the bottom of the airmatic strut. They appeared to be hardened and it took hours to drill it out with sharpened carbide masonary bits and then retap the hole in the strut to M10*1! At least I saved it, you can garentee the stealership would have condemed it if they had the car.
