I recently just bought a 2001 s500 with ABC suspension. I bought the car knowing the ABC wasn't working. Seller said it was a bad valve regulator and I noticed oil under the car where the valve was. No leaks from the struts were detected. The suspension was stuck in the highest setting and every time I went over a bump, the car would bounce up and down after the bump. I thought of fixing the system but I didn't want to replace the leaking hoses, the bad valve and plus the previous owner used regular red power steering fluid instead of the pentosin green fluid!!! That alone would have been a pain in the ass to flush out of the entire system. I've heard of all the horror stories regarding the cost of replacing or fixing the system as well as the stories of people having the car lower unexpectedly. Rather than go through this headache, I went ahead and bought the Strutmasters coil over conversion kit with the ABC light delete. Cost was $1600 shipped and I figured I could recoup most of the costs by selling the ABC struts and a replacement valve regulator that the owner included on ebay or worse case, sell the struts to Arnott for $200 a piece.
The install was pretty straight forward and I followed the videos on youtube. The only problem I encountered was that the quick disconnect lines in the front were frozen and would not disconnect. I used wrenches and a propane torch but nothing worked so I just disconnected the entire line up to the valve regulator and capped it off at the valve. The rears were a little harder to install since you have to take more of the suspension linkage off to get the strut out but the quick disconnects were not frozen and I was able to remove the struts without taking out the lines. The installation of the electronic box to get rid of the ABC malfunction light was pretty straight forward as well with only 4-6 wires to splice.
Now since I bought the car with the suspension not working, I have no idea what a normal working ABC suspension feels like. But I've driven the car with the strutmasters set up and everything feels like normal. No more bouncing around when going over speed bumps and no more loud noises when going over bumps. I'm very pleased with the results and I'm glad I did the conversion. I'm no longer afraid of driving the car and having the ABC leak fluid out, lower the car and get stuck somewhere. Car drives well on all the roads and smooth on the highway. Finally a smooth and quiet ride and my car doesn't have the stance of an SUV with a lower ride height!!
