Outside Temp & Sunlight Sensor - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-27-2013, 11:35 AM Thread Starter
Date registered: Aug 2013
Vehicle: 2002 S500
I am having an issue with my 2000 S500. I have searched the forums and read the stickypedia for everything written on these topics.
My outside temperature display in the cluster is completely blank and the climate control diagnostics report that it is -40 outside instead of +85 here in Texas.
I replaced the temperature sensor in the lower left bumper - still nothing..
I followed the wires until they disappeared.. No damage can be seen.
My sunlight sensor has also just been replaced due to a 1270 error in the climate control diagnostics. I reset and ran the scan again and I still have the same error.
I checked the fuse charts and neither device is mentioned so I assume that they are not fused items but just connected to the vehicle data bus.
My question is whether these two items get power from or are connected to the data bus in the same location so I have a place to start digging?
Thanks in advance
Dan.
englishdan is offline
post #2 of 8 (permalink) Old 09-27-2013, 01:03 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 250 Post(s)
Dan, you have done everything that comes to mind - sorry I can't offer any good help. I hope someone can.
PS - I love the term "stickypedia"!!
Warren
2010 S550
Formerly:
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is online now
post #3 of 8 (permalink) Old 09-28-2013, 06:23 AM
eric242340's Avatar
Quoted: 299 Post(s)
You will need the wiring diagrams to follow this, sorry but my copy of WIS is not working at the moment or I would dig out the diagrams, maybe another member has a copy of WIS?
ERIC.
eric242340 is offline
post #4 of 8 (permalink) Old 09-28-2013, 08:57 AM Thread Starter
Vehicle: 2002 S500
That would be great. I am going to look into getting my own copy. I have the feeling I am going to need it more than once during my ownership!
post #5 of 8 (permalink) Old 09-28-2013, 01:09 PM
Bullethead_D's Avatar
Date registered: Apr 2013
Vehicle: Cars: 2003 W220.184 (S500L 4matic) & 1950 W136.040
Quoted: 17 Post(s)
The outside temperature sensor is connected to the SAM left. The instrument cluster and the clima control unit get the value over CAN-B.
The sunlight sensor is connected to the clima control unit.
Bullethead_D is offline
post #6 of 8 (permalink) Old 09-28-2013, 02:19 PM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 250 Post(s)
See section 9 of the "stickypedia" for signing up for WIS.
Warren
2010 S550
Formerly:
2005 S500 4-Matic
2000 S500
1978 450SL
post #7 of 8 (permalink) Old 10-02-2013, 10:56 AM
Date registered: Sep 2013
Vehicle: 2004 S430
Out Door Temp Sensor
Just Solved Same Problem Installed New Sun Sensor Didn't Help Found The Outdoor Temp Sensor Behind Small Oval Shape Grille Lower Drivers Side Spoiler
Pulled Grille Out Found Wires Had Slipped Loose Reattached Everything Works Perfect Now Reinstalled Old Sun Sensor Every thing Still Works Perfect
Used Contact Cleaner On Temp Sensor And Plug Were Very Green I Suspect That The Green Was The Issue All Along
1coolman is offline
post #8 of 8 (permalink) Old 10-02-2013, 09:55 PM Thread Starter
Vehicle: 2002 S500
My sunlight sensor has some green on it too. I've used contact cleaner but I'm now going to use a needle on my meter lead to check continuity at the connector, if it fails I'm going to get creative with the soldering iron. Same goes for the temperature sensor.
Will keep you posted.
