4-matic engine mounts---DIY??
15K views 16 replies 10 participants last post by  cowboyt
evening gentlemen.
Mercy-Me was gracious enough to offer up the WIS for this procedure, which I'm hoping he'll post shortly. Has anyone done a DIY on this? If so, any shortcuts to the somewhat in depth factory procedure, which requires axle removal?
thanks all and mercy-me of course.
For what it's worth, I replaced the motor mounts on my 2006 S500 4matic just a few weeks ago it's even WAY more simple than the service manual suggests.
I was able to do both sides in 2 hours and didn't need to mess with loosening the steering rack or removing axle shafts etc. Now that I know how it's done, I can probably do them again (next time) in about 1 1/2 hours..
The right side comes out from the top-
Just remove the serpentine belt, alternator mounting bolts and move the alternator out of the way so the mount will come up through the area normally taken by the alternator.
The left side comes out from underneath between the sub-frame and the engine oil pan (you need to remove the plastic cover under the engine bay). Just remove the 3 bolts that hold the cooler lines in place to the oil pan/block so you can move the lines out of the way (they have rubber hose sections so you don't bend any hard lines doing this) and you can snake the mount in an out from that opening.
For me, I removed the white rubber covers off the mounts just to make them easier to handle while getting them into position and then slipped them back on once I got the mounts into position (before bolting them down).
If you're careful, you don't even need to disconnect the battery (I didn't) and you will obviously need a floor jack to support and lift the engine slightly to remove/replace the mounts.
Probably one of the easiest jobs I've done on this car.
:thumbsup:
#3 ·
Ollie, it looks like we have the answer we were looking for from ezobens. Thank you brother ezobens!
I will go ahead and post the WIS procedure documents anyway just so that you have them as promised.
Bob
(The dealer would have charged you the book rate which would have included the R&I of the entire front axle system.)
#11 ·
I really want to thank Ezobens. His method worked perfectly and me and a buddy knocked this out in a few hours today.
If we weren't fighting to put the alternator back in (the clearances are super tight), it would have taken about 2 hours.
MB dealers are making a killing on this because I'm certain they aren't following the work shop manual method. I imagine they could do this in about 1.5 hours and charge for 7.
bastards.
Thanks ezobens, engine feels great.
#17 ·
Hello Tony, and welcome to BenzWorld! It's always good to have another member that enjoys maintaining his/her own car. That's what we're all about around here.
Please take a moment to fill out your user profile with at least the following info.
1.) Specific model, and model year, of your car
2.) Whether or not it's a 4Matic
3.) Your general location in the world (country is fine)
The reason we ask for this is that MB made certain options available only on certain models, during certain years, in certain countries, and we do have an international membership. I happen to be from the USA. Others are from the UK, Australia, Nigeria, Lebanon, Japan, and so on.
Thanks in advance, and again, welcome!
owns 2003 Mercedes-Benz S600
Reactions: Dave2302
