Hello all! Still a little new here and wanted to ask..... I would like to change all interior lights to LEd including,trunk & plate/tag. Can someone throw me a bone as of what size LEds I need. Thx ahead for any info given
That would be great eFeJota. It looks like I'm about to pick up a 220 and this seems like a nice inexpensive mod. I've seen a lot of retailers claiming to have LEDs with built in load resistors that avoid error codes but obviously it's pretty simple for any online retailer to write checks they can't cash, so to speak.Hi, I've done many upgrades to my S320, including full LED interior mod.
For most cases it's a simple bulb replacement (T10 or festoon). But for minor cases, such as position lamps, lighting inside the trunk or license plate lights, you will need installing load resistors as consumption of LED is lower and that causes errors of flashing or malfunction. Personally, I don't recommend installing or solding load resistors because nowadays you can easily get LED lamps with built-in load resistors. The trouble is burning resistance that may ends up to undesided bulb replacement.
Give me some time and I'll upload photos and references for best match I finally got for a very low price.
Hey dude!! Nice write up. I did my interior in royal blue. Everything except the map lites. Can not get those tiny bulbs out so i just left them in. Did you get your out? I have a question is that a video screen up on the roof of your ride. Did the sunroof get in the way? Just wondering?Next, the CEILING LAMPS (if so called).
The front assembly needs 2 festoon bulbs (or panels). Both rear assemblies requires 2 festoon bulbs (or panels) and 2 T10 (or W5W) bulbs each.
I replaced only festoon bulbs to white led. I preferred to leave the original T10 bulbs for rear mirrors, but you can easily upgrade them to led the same way.
So the issue is as follows.
Total pieces needed: 6. Type of bulb: festoon led. No load resistors required.
In this case I chose 9 SMD 39mm bulb instead of panel, but you can use the one you like or the least cost you.
A bit of advice: 9 SMD leds (x6 pieces) are bright enough to illuminate. May be even too.
I installed them in white because I think it's the most appropiate. Blue, red, green, orange, etc. is not my choice.
Pictures say it all...
Any idea how to change the lights under the dash for the front floor board lights or in the lights in the rear floorwell down by your feet?Now the TRUNK LAMPS.
The inside lighting needs 2 festoon bulbs (or panels) and the light up next to the triangle requires 1 T10/W5W bulb (or panel).
One of the two, festoon or T10, must be error free (load resistor built-in) or original bulb.
If you want you can easily replace the 3 (2+1) pieces to led.
Total pieces needed: 3. Type of bulb: 2 festoon led + 1 T10/W5W. At least one error free bulb, eather the festoon or the T10.
I installed all three in white colour to get clearer light inside trunk. I have not used panels, but bulbs. Faileth probably changing the T10/W5W bulb by a panel in orange colour. Not the case by now.
The festoon bulbs I assembled are 39mm and error free type. However, the T10/W5W is not error free required because they are the festoon.
You could do it backwards: festoon leds without load resistor built-in but T10/W5W error free.
Use whatever you want.
In my case both festoon are 6 SMD led error free. Light with 12 leds get more than enough to find anything in the trunk.
2 are in rear footwell. 1 in center console. Where is the fourth one?the FOOTWELL LAMPS upgrade to a more luminous ambient light. The W220's got 4 of these footwell lamps. I assume that anyone interested in this topic knows exactly where each are located.
