Originally Posted by El Prez Thanks for the reply. I have tried a number of flat screwdrivers and other such tools but it seems to be very tight and I don't want to break anything. Is there a trick to this? |
No, no trick is needed. Just simple and I don't even remember how I did it.
I don't think you can break anything. The circuit board is sandwiched between the two halves of the case. It is not easy to damaged even you break the plastic case/cover.
Good luck.
Howard
