Rear Brake Light Stays on - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 10-01-2012, 10:41 AM Thread Starter
Date registered: Jan 2009
Red face Rear Brake Light Stays on
Hello everyone,
can anybody help me sort this problem out,
my "99" W220, has developed a brake light problem,
the brake lights work, but when you park up and remove the ignition key, the nearside brake light stays on, not fully on (as in fully lit up) but the lighting around it (you know what i mean) and it will not go off, i have had to disconnect the battery to stop it being drained.
i have checked the bulbs and all seem ok, there is a little rust, on the side light holder, which i have cleaned, but that was working anyway.
Any Ideas......
Thank's in anticipation.
Les.
lesmac007 is offline
post #2 of 11 (permalink) Old 10-01-2012, 11:41 AM
Date registered: Jan 2012
Vehicle: S55 AMG
Its maybe a bit obvious, but have you left one of the parking lights on?
astroscan is offline
post #3 of 11 (permalink) Old 10-01-2012, 12:39 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
That's weird, for sure.
If you disconnect the rear lights assembly you can use a multimeter to check voltages on the connector pins. You can compare the left and right sides.
Without the brake on, you should have no voltage on the pins below. With the brake on you should have 12 vdc. Also check for good continuity of the earth pins to chassis.
E3e4 pin 3 is the supply for the left stop lamp. Earth is pin 7.
E4e4 pin 5 is the supply for the right stop lamp. Earth is pin 1.
If you have a supply voltage there with no brake switch operation, it sounds like a fault in the rear SAM.
keyhole is offline
post #4 of 11 (permalink) Old 10-03-2012, 10:43 AM Thread Starter
Thanks for your reply, i have posted a video on You Tube
Just in case it helps...
Thanks
Les.
post #5 of 11 (permalink) Old 10-03-2012, 05:51 PM
keyhole's Avatar
Quoted: 375 Post(s)
Just noticed from my WIS that your rear stop lights (and also the center brake light) are LED and not the same as the others in the rear light assembly.
I wonder if the LED is picking up a stray voltage from somewhere. As you said earlier it does not seem to be the normal brightness.
Does it work as a stop light when operated? Or just stay on low permanently? As it is LED, it probably would not flatten your battery overnight. Try swapping with the other side to see if the fault remains.
keyhole is offline
post #6 of 11 (permalink) Old 10-04-2012, 12:49 PM Thread Starter
Thanks for your reply keyhole,
the brake lights work perfect, and although the problem lighting is very low, in the dark it looks a lot brighter, i have to admit i would'nt know how to remove the lcd's to swap them over...?
Regards
Les.
post #7 of 11 (permalink) Old 10-04-2012, 06:23 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2010 S550
Quoted: 243 Post(s)
Just a thought - the fog light setting is for one tail light to be on, and very bright. To activate it, one turn the headlights on and pulls the switch outward to the second stop.
I do not know what the fog lights do if the ignition is off and the key is removed. But you might check that you don't have the switch positioned so that the rear fog light on.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #8 of 11 (permalink) Old 10-05-2012, 06:14 AM
keyhole's Avatar
Quoted: 375 Post(s)
Hi Les
Without using a multimeter, and checking voltages/resistances from a wiring diagram, I don't see how you can trace this electrical fault.
Maybe it is 'auto-electrician' time here...
keyhole is offline
post #9 of 11 (permalink) Old 11-18-2014, 03:37 PM
Date registered: Nov 2014
Hi Les, I have the same problem have you managed to fix the problem?
LMoto is offline
post #10 of 11 (permalink) Old 01-29-2016, 01:52 PM
Date registered: Jan 2016
Exclamation
Originally Posted by lesmac007 View Post
Hello everyone,
Any Ideas......
Les.
Hello,
I am searching online for references to this problem and it sounds EXACTLY like what mine is doing. It is the left rear taillight only. And only the side strip of 4 or so LEDs that are lit up. Not the main bank of taillights on the back.
I am assuming it is either a switch or a relay issue.
Did you have any luck?
Movinginstereo is offline
