AC compressor internal damage, should replace what other parts? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-01-2012, 06:06 PM Thread Starter
Date registered: Mar 2008
Quoted: 5 Post(s)
I read some where that if your HVAC compressor has internal damage you would need to replace the following items:
Compressor
intake and pressure lines with seal rings
expansion valve
receiver/drier
I don't have a problem replacing every thing that should be replaced I'm just not sure if this is normal procedure?
Also at what point in this repair should the other parts be flushed out?
Does this system have a orifice filter? Alldata didn't show one.
1999 SL500 155k miles
2003 C32 155k miles
2002 S55 178k miles
2004 S430 210k miles
2003 E320 110k miles
2004 E500 180k miles
2003 E500 120k miles
CarBizIndio is offline
post #2 of 4 (permalink) Old 06-01-2012, 08:31 PM
jnash's Avatar
Date registered: Apr 2005
Vehicle: 2003 S55 AMG
Quoted: 29 Post(s)
yes, that list is correct, except I did not replace the lines.
See this http://www.benzworld.org/forums/w210...ac-system.html there are 3 sections, thats the first one.
There is no orifice filter, its controlled by the expansion valve.
2003 S55
K&Ns, 80mm TB, NPI headers, X-pipe / 3in pipes, Kleemann Cams & 168mm Pulley, ECU & TCU tune. 550cc injectors, Meziere WP136S SC pump. UPD SC pulley & SC belt wrap, Alum idler pulley set. Fuel rail loop, LFR7AIX plugs, NPI heat exchanger, -10C mod, shift paddles, TeleAid removed.
Lowering links (1.5" front, 1" rear), 18x9.5+35 offset rims, clear side markers, KG Key retrofit, H/W Valentine1, BT phone, BT AUX, laser jam, upgraded fans in seat backs, inline ABC mag filter.
jnash is offline
post #3 of 4 (permalink) Old 06-01-2012, 09:17 PM Thread Starter
Quoted: 5 Post(s)
Outstanding gathering of information. I noticed there was no talk about flushing the system. I'm guessing this isn't normal practice?
2003 C32 155k miles
2002 S55 178k miles
post #4 of 4 (permalink) Old 06-02-2012, 10:28 AM Thread Starter
Quoted: 5 Post(s)
I think denso makes the oem part for benz. Any one have any problems with the ebay denso compressors?
2003 C32 155k miles
2002 S55 178k miles
    ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 16 06-22-2010 09:26 PM
    WANTED: Internal spring compressor southbusiness For Sale/Wanted/Trade/Giveaway 6 05-02-2009 05:16 AM
    300 D versus 300 DT internal engine parts Captcod General Mercedes-Benz 3 10-29-2008 11:35 AM
    Internal parts for c280? weaksauce W202 C-Class 1 09-07-2008 04:53 PM
    Replace wiring harness to prevent Damage???? K&C124 W124 E,CE,D,TD Class 0 10-04-2005 08:25 PM
