Front end rumble...upper control arms? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-02-2012, 08:01 PM Thread Starter
Date registered: Sep 2011
Vehicle: 02 G500, 01 Saab 9-3, 99 Pors 911. Past: 00 S500, 00 Rover, 04,99 Jag xj8, 95 Alfa 164
Quoted: 6 Post(s)
Well, to date, I have replaced the following front end components with OEM:
Control Arm Bushings
Lower Ball Joints
Air Struts
Lateral Arms
Sway Bar w/bushings
End Links
With each replacement, the front end keeps getting tighter, but I still get a rumble or light rattle over shallow bumps at a low speed from the passenger side only. Based on process of elimination, I'm assuming this must be the Upper Control Arms, but I thought I would see what you guys think before I drop another $700 into the front end!
dmarti02 is offline
post #2 of 6 (permalink) Old 02-03-2012, 07:28 AM
Date registered: Feb 2009
Vehicle: S500 | 220.175 | 113.960
Did you try raising the front end and rcoking the wheel, wiggling it up down left right?
Often at times a worn out control arm may give the wheel some play that may be felt. However any mechanic should do a visual inspection at no cost
lyoooha is offline
post #3 of 6 (permalink) Old 02-03-2012, 08:52 PM Thread Starter
Quoted: 6 Post(s)
Plenty of mechanics looking at this one. I don't think the arms are showing any notable wear, but the rumble is obvious. Based on what I replaced, could it be anything else?
dmarti02 is offline
post #4 of 6 (permalink) Old 02-04-2012, 02:34 PM
Date registered: Jan 2012
Vehicle: 2000 S500 W220
Try checking out the inner and outer tie rods. I currently have the rattle and thats actually where I'm going to start, and then work my up to the control arms eventually.
Stef2584J is offline
post #5 of 6 (permalink) Old 02-04-2012, 08:09 PM
Date registered: Oct 2011
Vehicle: 2006 Mercedes S55 AMG
Send a message via AIM to cmpcpro Send a message via Yahoo to cmpcpro
Hmmm.. I am convinced I have something like that in the rear end.. the front seems solid, but sure would like to figure it out.. I am wondering if it is normal with the air suspension.. I agree with the above on the tierods.. very well could be it.. how tight is your steering?
Chris
2006 Mercedes W220 S55
1956 Oldsmobile 98 Holiday 2dr/hardtop
2016 Toyota Camry XLE Hybrid (commuter)
Previous Mercedes:
2010 S550
2008 S550
2000 S430
1990 300D
cmpcpro is offline
post #6 of 6 (permalink) Old 02-05-2012, 06:06 AM Thread Starter
Quoted: 6 Post(s)
The steering is very tight with no play, that's why I'm thinking upper arms. I guess on the one hand, I'm simply running out of parts to replace, so it's one or the other.
dmarti02 is offline
    possible upper ball joints/upper control arms?? 98e430sport W210 E-Class 7 03-30-2011 03:56 AM
    Upper Control Arms Front Suspension mike430sport W210 E-Class 7 04-17-2010 08:16 AM
    Little help? Upper control arms ScottinSoCal R/C107 SL/SLC Class 16 07-30-2007 12:49 AM
    Upper Control Arms Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 14 05-23-2007 06:42 PM
    front upper control arms gcmazza W140 S-Class 29 05-26-2006 09:10 AM
