No Heat After Flushing & Changing Coolant - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-26-2011, 07:38 PM Thread Starter
punchpro68's Avatar
Date registered: Oct 2007
Vehicle: 2002 S430
After flushing and changing the coolant on my '02 S430, I no longer have any heat in the car?? I drained the system first, then flushed out with water, and filled with 50/50 mixture of MB coolant. Now, there is no heat. I tried the REST button but no heat either in front or rear. The car seems to warm up to normal temp 80 - 90 C but only cold air coming from the vents. Any help is appreciated.
punchpro68 is offline
post #2 of 9 (permalink) Old 12-26-2011, 08:13 PM
Date registered: Oct 2011
Vehicle: 2008 Mercedes Benz S550
Send a message via AIM to cmpcpro Send a message via Yahoo to cmpcpro
Did you try driving it? I flushed my coolant multiple times when I changed it and I had to drive it before it would start getting warm the first time..
cmpcpro is offline
post #3 of 9 (permalink) Old 12-26-2011, 09:02 PM Thread Starter
punchpro68's Avatar
Vehicle: 2002 S430
Yes, I drove the car for about 20 minutes. Car was at temp about 80 C. Still only cold air from vents. When I filled the system, I was only able to fill 4.5 quarts of MB antifreeze & 4.5 quarts of water and system was full. I thought it would be about 6 quarts of each as capacity of cooling system should be 12 quarts per specs.
post #4 of 9 (permalink) Old 12-27-2011, 04:16 AM
Vehicle: 2002 s500, 2004 S500 fourmatic
When I changed the duovalve pump motor, I also changed the antifreeze/coolant at the same time. If everything was working before you did the activity, I'm almost 100% sure that you have an air bubble (large) in the heating lines preventing the flow of fluid. I actually had similar results initially, but I knew that the duovalve pump is situated high on the firewall and expected this kind of problem, so, I parked the car on an angle (front end high) to help the trapped bubble of air escape. Helped a little, but what is really going to help the most in this case, is alternate heating and cooling. With the system under pressure, it will dissolve a little of the air into the coolant. When it cools down, the air will displace, but into a different area of the engine. Over a few cycles, the heater hoses/heat exchanger blockage will go away, but you will now need to add more coolant to make up for the space consumed. Check your coolant reservoir when it has cooled down to see if it needs more coolant. It will probably just be a time thing.
I seem to remember that I only required (2) gallons of antifreeze to charge the system, but, when I installed the new pump, I had it mis-aligned (off 90 degrees) and lost some antifreeze through the imperfect sealing.
tower is offline
post #5 of 9 (permalink) Old 12-27-2011, 02:50 PM Thread Starter
punchpro68's Avatar
Vehicle: 2002 S430
Tower, thanks for your insight & comments. Everything was working before I changed the antifreeze/coolant. I actually lifted the front end also during the coolant change to see if this would help. I checked the level this morning and it was still at the same level as before... no change? Thought it would have settled some. My thoughts were along the same lines, Tower....that there must be an air bubble. This is probably preventing the duovalve/ water pump from picking up suction and moving fluid. You're right that it's situated relatively high on the firewall which doesn't help matters when you're first charging the system. The coolant system should have a bleeder valve somewhere to help prevent this!!!....I looked and couldn't find one.
Well, at this point I took the car to my INDY mechanic. I gave him the background and he fixed it within 2 hours. He checked the AC / heat system and found all components working. He said the system was airbound. No real explanation as to how he got the air out. Probably got it on the lift & disconnected hoses.
post #6 of 9 (permalink) Old 12-28-2011, 06:57 AM
What also doesn't help the situation, is that the W220 relies on the auxiliary pump to provide coolant during slow rpm situations, as in idling. Idling the car waiting for the "bubble" to dissipate will not work as the water pump cannot circulate enough coolant to "flush" the bubble through. You might have better success than I did by "burping" the coolant feeds next time in an attempt to force the bubble down the system.
But its working now. You should get the mechanic to explain what he did to prime the system so that we all know in the future.
Tower
tower is offline
post #7 of 9 (permalink) Old 08-01-2015, 08:24 PM
Date registered: Feb 2014
Vehicle: 2005 C 240 4Matic sedan
Same thing happened to me after I have flushed old coolant away and put new one on my 2005 C240. Heater refused to heat Don't worry just drive your car after you topped up coolant to the correct level. Evey thing will return to normal after several miles of drive. That is just air bubble trapped and system get rid of it with time.
Happy driving Mercedes lovers
dexter_morgan is offline
post #8 of 9 (permalink) Old 08-02-2015, 01:03 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 775 Post(s)
Flushing Brake fluid , flushing coolant , and alignment are the three things you should use a indy or dealership for . They don't charge much labor and it's done correctly . These cars just aren't easy to do right
tusabes is offline
post #9 of 9 (permalink) Old 08-03-2015, 06:07 AM
ki5yk's Avatar
Date registered: Feb 2010
Vehicle: 2003 SLK320 2003 S600
Quoted: 6 Post(s)
Best DIY way to prevent "air lock" bubbles in cooling system is to use a vacuum purge device to remove the air prior to reintroducing coolant into the system. The device pulls a vacuum on the empty cooling system to remove all air, then you valve in a pickup tube to introduce fresh 50% coolant back into the system - it being pushed into the system by atmospheric pressure (due to vacuum in the closed cooling system).
I have used a device similar to this to eliminate air pockets in the intercooler cooling system on my S600 with great success as well as replacing the engine coolant in the S600, SLK320 as well as a couple of GM duramax diesel pickup engines.
Regards,
Chuck
Michigan, USA
2003 SLK320
Magma Red /Red-Black interior/6-speed Man.
2003 S600
Black /Anthracite interior
ki5yk is offline
    Flushing coolant chimchongdlight W202 C-Class 0 12-08-2011 09:04 PM
    Tips on Flushing coolant jdeanmc W210 E-Class 46 07-30-2009 07:36 AM
    Flushing coolant gdvine W123 E,CE,D,CD,TD,TE Class 0 09-02-2004 07:03 PM
    87 300 SDL, Bleeding Brakes and Flushing Coolant ?'s Jack in FL W126 S,SE,SEC,SEL,SD,SDL Class 1 10-16-2003 08:28 PM
    87 300 SDL, Bleeding Brakes, Flushing Coolant ?'s Jack in FL W124 E,CE,D,TD Class 1 10-14-2003 07:43 AM
