2002 s500 wipers not working - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-06-2011, 11:38 AM Thread Starter
Date registered: Jan 2008
Vehicle: 2002 S500
I am stumped, I have no power at the wiper motor, changed out 2 relays in drivers side box that I was told may be suspect, replaced signal/wiper stalk, have non feature idea what else to check all fuses seem to be ok. My local mechanic is also stumped weird thing is he got it working for like 2 minutes when he swapped out different relays, but that may be a coincidence. I did have past issues once windshield was replaced that the intermittent feature stopped working but did not affect other speeds. also I am having issue with steering wheel adjustment not working?? poss. related? Any suggestions what I am missing? nextstep is to bring it to the dealer, problem is it is the only car I have presently, but if thats what I need to do so be it, but I wanted to ask here first, Any help would be appreciated..Forgot to mention when I press the wiper arm in for spray it does work, but thats all...no wiper function in any speed
johnnyo is offline
post #2 of 9 (permalink) Old 11-07-2011, 08:53 AM Thread Starter
Vehicle: 2002 S500
Just ordered a SAM only thing left that I can imagine causing my issues, Any other ideas?
johnnyo is offline
post #3 of 9 (permalink) Old 11-08-2011, 02:37 PM
Date registered: Jan 2010
Vehicle: 2000 and 2003 W220 S500
With a SAM on the way, check to see what could've fried that SAM; water, etc.
Gabby07621 is offline
post #4 of 9 (permalink) Old 11-12-2011, 08:20 AM Thread Starter
Vehicle: 2002 S500
As a follow up and to assist any others with same issues, I had the SAM replaced which was purchased at EBAY, Ha, Stealer did not get my money, lol. and problem has been resolved. There was a little trial and error on my part. replaced good functioning stalk, checking power at wiper motor. changing out 2 relays, but all in all end result was good. I did all I could in researching here and other site to give me a direction without having to throw too many parts or labor to correct issue. But from what I've read even the dealer seems to do the same as I had done from what I've read here.
johnnyo is offline
post #5 of 9 (permalink) Old 11-12-2011, 08:49 AM
Date registered: Jun 2009
Do you have link to the eBay auction, what does the SAM look like?
tabocat is offline
post #6 of 9 (permalink) Old 11-12-2011, 09:22 AM Thread Starter
Vehicle: 2002 S500
The SAM is an acronim for signal acquisition module. it is located at the front drivers side and is where your relays and fuses attach to. Best way is to do a search in ebay under SAM Mercedes (car model) quite a few should come up. you should pay no more than $100-$150 with all relays intact. when installing do not forget to disconnect the battery. If you need any help sourcing the init let me know I will help you find it on Ebay...no problem
johnnyo is offline
post #7 of 9 (permalink) Old 11-16-2011, 09:10 AM
Date registered: Feb 2008
Vehicle: 2004 (w220) S500 & 2001 CLK320 Cabriolet V6 3.2 L
Quoted: 5 Post(s)
did it fix
Is the intermittent wipe feature working now? rain sensing?
poptopclk is offline
post #8 of 9 (permalink) Old 11-16-2011, 10:20 AM Thread Starter
Vehicle: 2002 S500
All is working fine now I do have a seperate issue with intermittent function since changing the windshield. this issue predated the issues of the wipers not working at all. Also I was having issue with my rear left blinker not working which has also been corrected since swapping the Sam.
johnnyo is offline
post #9 of 9 (permalink) Old 01-15-2016, 12:49 PM
Date registered: Jan 2013
Hi
i think that i have the same issue, everything works with the exception of the wipers in any position. I have just purchased the car with this fault. The previous owner replaced the wiper switch, and then gave up. If the battery is disconnected, sometimes the wipers work for a short time. I am thinking LH front SAM? Is it worth changing it and seeing if it works? There are no error codes.
The car is a W220 S500 with HID lights UK spec right hand drive.
i am thinking of getting the part number and then getting a used one from Ebay.
what do you all think?
open to input.
the rest of the car is super and it seems to have almost every option.
thanks Robin
robin993 is offline
2003 S500 wipers not working cwdtmmrs W220 S-Class 7 11-05-2010 11:22 AM
Wipers have stoped working smil2921 R170 SLK-Class 1 06-25-2009 06:06 PM
PLEASE Help. PW and wipers not working now 604azn604 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2008 06:36 AM
wipers not working brian/ont W163 M-Class 5 01-17-2006 06:20 PM
headlamp wipers not working mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-23-2005 08:11 AM
