Can a bad relay cause a fuse to blow - Mercedes-Benz Forum
post #1 of 33 (permalink) Old 11-02-2011, 10:21 AM Thread Starter
Date registered: Nov 2009
Vehicle: 2004 S430
Just a thought here but i was thinking about it, could a bad relay for the secondary air pump cause a fuse to blow?
2004MBS430 is offline
post #2 of 33 (permalink) Old 11-02-2011, 05:23 PM
jnash's Avatar
Date registered: Apr 2005
Vehicle: 2003 S55 AMG
Quoted: 29 Post(s)
general answer
Typically relays draw a minimum amount of current to hold the contacts together while energized. I have never seen a relay coil short ciruit that would cause alot of current to flow and therefore blow a fuse. Most common failure with a relay is the actual contacts or less likely the energizing coil goes open circuit and no current flows to energize the contacts. If your suspect your particular relay is electronic rather than electro-machanical then its possible but unlikely as it too would more likely by design go open circuit.
See if there is an identical relay from another circuit in teh fuse box, try it, and then see if the fuse blows again. If it does its not the relay. Then put the supsect relay in the other location and test.
2003 S55
K&Ns, 80mm TB, NPI headers, X-pipe / 3in pipes, Kleemann Cams & 168mm Pulley, ECU & TCU tune. 550cc injectors, Meziere WP136S SC pump. UPD SC pulley & SC belt wrap, Alum idler pulley set. Fuel rail loop, LFR7AIX plugs, NPI heat exchanger, -10C mod, shift paddles, TeleAid removed.
Lowering links (1.5" front, 1" rear), 18x9.5+35 offset rims, clear side markers, KG Key retrofit, H/W Valentine1, BT phone, BT AUX, laser jam, upgraded fans in seat backs, inline ABC mag filter.
jnash is offline
post #3 of 33 (permalink) Old 11-02-2011, 05:25 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Yes.
Mercedes mechanic is offline
post #4 of 33 (permalink) Old 11-02-2011, 05:54 PM Thread Starter
Vehicle: 2004 S430
thank you for your replies. I tested the relay and it was working so i ruled out a bad relay. I believe i found the culprit, the positive wire that goes to my secondary air pump had melted to the pump just short of the plug which i suspect was causing a short which was causing the fuse to blow in a protective measure for the pump. Your thoughts? i will have to wait till morning to determine if i found the problem because the secondary air pump only runs on cold starts
post #5 of 33 (permalink) Old 11-02-2011, 06:00 PM
Im not meaning to scare you. But you need to dis-assemble your K40, and inspect the circuit board. My bet is that the 40 amp (huge) fuse has loose/burned soldier connection's.
When the air pump draw's enough amp's it will burn the board but not pop the 40 amp.
post #6 of 33 (permalink) Old 11-02-2011, 07:48 PM Thread Starter
Vehicle: 2004 S430
not to sound stupid but what is the k40?
post #7 of 33 (permalink) Old 11-03-2011, 07:31 AM Thread Starter
Vehicle: 2004 S430
Also where is the k40 located? Thank you, by the way i started it this morning and promptly blew another 40 amp fuse so i am learning toward what you said about the k40, i just need to find it
post #8 of 33 (permalink) Old 11-03-2011, 08:04 AM Thread Starter
Vehicle: 2004 S430
where and what is the k 40?
First off thank you all for helping and getting me this far. I need some additional help locating the k 40 for my car any help or pictures you can provide are greatly appreciated.
Last edited by Skylaw; 11-03-2011 at 09:47 AM. Reason: merged with earlier thread to keep related matters together
post #9 of 33 (permalink) Old 11-03-2011, 09:30 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 251 Post(s)
There is a relay at position K in your right front fuse box. See http://www.benzworld.org/forums/w220...e-diagram.html
I don't know if Mercedes mechanic is referring to the board this relay is mounted on.
Permalinks 8 and 9 were merged with your earlier thread to keep responses from being scattered.
Warren
2010 S550
Formerly:
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #10 of 33 (permalink) Old 11-03-2011, 09:47 AM Thread Starter
Vehicle: 2004 S430
Hi Skylaw,
I have been chasing a CEL (p0410 i believe) which is a secondary air injection fault. I noticed that i kept blowing fuse f31 on cold start (went through 3 or them to confirm) and found that the positive wire coming off the plug to me Secondary air pump had melted partially (which i thought was causing a short and blowing the fuse). I wrapped the wire with electrical tape and replaced the fuse (f31) and it still blew the fuse this morning. Member "mercedes mechanic" suggested that i look into the k40 circuit board and see if anything had been burned out. I am also in the process of trying to bench test my secondary air pump to ensure that it is also working. I hope that this adds some perspective
    c320 fuse #65 blow out help!!! fili209 W203 C-Class 4 11-06-2011 04:16 PM
    Did I blow a fuse, or worse? MX-5.0 R/C107 SL/SLC Class 1 06-16-2011 11:17 PM
    87 420sel fuse#5 starting to blow dstrybos W126 S,SE,SEC,SEL,SD,SDL Class 0 05-09-2011 01:38 PM
    Repeated Fuse Blow on Fuse #7 mem W163 M-Class 2 03-16-2010 06:09 AM
    Wiper Relay would blow fuse? jef_1_f R129 SL-Class 3 05-21-2007 11:39 PM
