Replacing thrust (aka lateral) arms only - Mercedes-Benz Forum
post #1 of 40 (permalink) Old 10-31-2011, 03:23 PM Thread Starter
Date registered: Sep 2011
Vehicle: 02 G500, 01 Saab 9-3, 99 Pors 911. Past: 00 S500, 00 Rover, 04,99 Jag xj8, 95 Alfa 164
Quoted: 6 Post(s)
I've been gradually replacing suspension components. It would have been nice to do everything at once, but while striving to only replace what's worn, EVERYTHING seems worn!!
Anyway, I've done ball joints, control arm bushings, end links, struts and still have a slight creaking noise when occassionally stopping. I inclined to think it's the lateral arms which has been confirmed by the dealer.
Two questions: How is this DIY if it's the only thing I'm replacing?
While I'm inclined to keep using OEM for all my parts, I noticed that AutohauzAZ has Febi (which I believe is Boge) for a decent price. Any thoughts on using them over the OEM?
dmarti02 is offline
post #2 of 40 (permalink) Old 11-01-2011, 06:05 AM
mjd
mjd's Avatar
Date registered: Aug 2008
Vehicle: 94 E320 Sportline sedan 86 190E 2.3 16V sedan 04 S430 Sport
Quoted: 2 Post(s)
dmarti02, you can repalce these arms fairly quickly and easily without disassembly of any other of the front suspension. You will need an alignment done after the swap, and personally I only used MB OEM parts when I rebuilt my front end, but I also get wholesale pricing from my dealer so the cost difference between aftermarket and OE was minimal.
You can order OE parts at wholesale pricing from MB of Ft Lauterdale here: http://www.trademotion.com/partlocat...&siteid=214089
mjd is offline
post #3 of 40 (permalink) Old 11-01-2011, 10:24 AM Thread Starter
Quoted: 6 Post(s)
Thanks for the link. parts.com is even cheaper for OEM MB by like $15 each on that thrust arm. Autohauz only wants $128. I guess I'm trying to justify saving a bit, since I'm pretty exhausted pouring money into this car.
dmarti02 is offline
post #4 of 40 (permalink) Old 11-01-2011, 01:15 PM Thread Starter
Quoted: 6 Post(s)
Has anyone had experience with Febi front end parts?
dmarti02 is offline
post #5 of 40 (permalink) Old 11-01-2011, 04:06 PM Thread Starter
Quoted: 6 Post(s)
I promise to stop bothering everyone, but I have one more question regarding this. What are the odds I can get the thrust arm removed without buying a ball joint separator? On this particular joint, has anyone had luck with the trusty pickle fork?
dmarti02 is offline
post #6 of 40 (permalink) Old 11-01-2011, 04:45 PM
mjd
mjd's Avatar
Quoted: 2 Post(s)
your not bothering... that is what we are here for....
if you dont have the "proper" joint seperator you can use a pickle to seperate, and I only say that because you are replacing the aluminium arms. The steering knuckle is cast so you can't damage that as easily. The reason they recommend using the joint sperator is to avoid damage to the softer aluminium parts... such as the lateral arms. But again you are replacing them so if you scare them up using the fork no biggie.
mjd is offline
post #7 of 40 (permalink) Old 11-01-2011, 05:25 PM
xexpo's Avatar
Date registered: Sep 2009
Vehicle: 2000 S430 156k (11/12)
dmarti02: No bother at all. I actually enjoy helping whenever I can.
I have not used Febi but did use Lemforder lower arm, they seem to be holding up good. I did notice one thing though, when I took off the set screw to separate the strut from the ball joint, I saw that the set screw dug into the area where set screw holds the top of the ball joint. Checked the old ball joint on the original arm and that was not evident at all.
I've always read that the rubber and the ball joint materials are inferior to the Genuine Mercedes arms and it seems to be true in my experience. Febi control arm is a lot cheaper then the Lemforder, I don't know if the quality is there.
If you're not keeping the car more than couple of more years, Febi might make sense.
You could also barrow the ball joint separator from either Advance Auto or Autozone, no charge.
Below is the DIY for the front lower control arm.
xexpo is offline
post #8 of 40 (permalink) Old 11-01-2011, 09:03 PM
Date registered: Oct 2011
Vehicle: 2008 Mercedes Benz S550
Send a message via AIM to cmpcpro Send a message via Yahoo to cmpcpro
I would stick with OEM.. The BMW gang hasn't had the best luck with Lemforder..
cmpcpro is offline
post #9 of 40 (permalink) Old 11-02-2011, 06:11 AM
xexpo's Avatar
If you're keeping the car, Genuine Mercedes Benz for sure.
xexpo is offline
post #10 of 40 (permalink) Old 11-02-2011, 07:25 AM Thread Starter
Quoted: 6 Post(s)
Thanks for the assistance. I think I'll go OEM on the this job. While I rarely keep a car that long, I usually get burned on non-OEM on the install. There are always good suppliers out there, but based on the response, this is not an area to chinze on. I still can't believe what I've invested in this front end, which included struts unfortunatly!!!
dmarti02 is offline
    Replacement of Lower Control / Thrust Arms (DIYers are Welcome!) lyoooha W220 S-Class 13 06-23-2015 10:29 PM
    Pictorial DIY: Replacing Lateral Movement(Acceleration) Sensor Kobus R170 SLK-Class 17 07-16-2013 08:23 AM
    Replacing front control arms mik100 R129 SL-Class 4 09-14-2010 01:08 PM
    Replacing Lateral Acceleration Sensor for 2001 ML320 benjaminl W163 M-Class 12 06-25-2010 09:31 AM
    what is a fair price to replace thrust arms? netnerd W203 C-Class 2 04-12-2010 11:59 PM
