Car battery dies after left sitting for one or two days? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 09-25-2011, 06:47 AM Thread Starter
Date registered: Sep 2011
Vehicle: 2001 S500
Angry Car battery dies after left sitting for one or two days?
I just joined on here because I just bought a S500 2001 Mercedes and it has been in shop more then in my garage. I need some advice bad. My car battery dies about every two days and wont start totally dead. I took it to dealer and they ran a diagnostic on it and said that it was the command center which is the stereo and everything. They said it was cranking out to much voltage or something and it was the reason it wouldn't start every other day they said it would be 1k for new unit. I said nahhh can you just disconnect it or take fuse out. So they did. After few days the car would not start again! So they were incorrect!!!!!! what do I do???? Also I need a new a new suspension compressor cause everyday after parking it for the night the next morning when I go to car the front end is almost sitting on tire then when I would start it, it goes back up to normal. They said that wouldn't be the issue with the battery. SO does anyone have any info on this? I need help bad, its driving me crazy
Benz01-S500 is offline
post #2 of 12 (permalink) Old 09-25-2011, 07:18 AM
deucer's Avatar
Date registered: Apr 2011
Vehicle: '02' S500 (W220)
Quoted: 23 Post(s)
1. How old is your Battery? Will it hold a charge without connecting to car? Verify your battery will hold charge by having it tested at an Auto parts shop like AutoZone...
2. If battery is good and holds a charge, then it is possible for electrical drain after key is turned off due to the Command not shutting down properly, i.e. Radio, Navi or something is still running after shut down. Possible solution is to Push Power button (on center console) to OFF before turning key to off position. I can not confirm this works, but is plausible.
3.New Suspension Compressor replacement? Before you purchase, who troubleshot and concluded your compressor was bad? I'd would first be looking for a leak at the Strut or a fitting loose...
My 2 cents worth,
deucer
deucer is offline
post #3 of 12 (permalink) Old 09-25-2011, 12:24 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 256 Post(s)
Welcome to the forum.
The W220 S-Class Encyclopedia sticky at the top of the forum contains a section on excess quiescent battery drain under "Electrical System." What deucer advises is correct. The Encyclopedia links contain additional troubleshooting steps to identify the cause of the problem.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #4 of 12 (permalink) Old 09-25-2011, 12:42 PM Thread Starter
Vehicle: 2001 S500
thank you all so much, I'm gonna check it out... I keep thinking its the compressor draining the battery since it keeps dropping to tires when shut off then pumps it back up when started (when it starts).....
post #5 of 12 (permalink) Old 09-25-2011, 01:13 PM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 256 Post(s)
If you have an airmatic leak bad enough to drain your battery, it will also burn up your airmatic pump, very quickly. You'll want to tend to that promptly. See the S-Class Encyclopedia entries on Airmatic, too.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #6 of 12 (permalink) Old 09-25-2011, 08:14 PM
eric242340's Avatar
Quoted: 307 Post(s)
When you park the car for one or two days remove the airmatic relay, this will help to identify any drain via this means.
ERIC.
eric242340 is online now
post #7 of 12 (permalink) Old 09-26-2011, 11:48 AM Thread Starter
Vehicle: 2001 S500
@ deucer I had the battery tested they said it was fine so idk. Wouldn't start this morning again. Called dealer and said hey car wont start again and fuse to command center is still out so that's not the problem.I said well I think its the compressor trying to pump the car back up after its in park or something. HE said maybe, so you'll need to get a new compressor. I said its pumping the car back up when started so why would I pay 624 for new compressor? Its obviously leaking out somewhere, he said well let me ask my Mercedes service guys and I'll call you back. I have never dealt with so much stress and problems from an automobile.
@eric242340 where is the airmatic relay at? How can I remove it?
post #8 of 12 (permalink) Old 09-26-2011, 01:49 PM
deucer's Avatar
Quoted: 23 Post(s)
Assuming whomever tested your battery applied a load to it to ensure voltage would sustain, Good... Eric provided you with a great idea by popping the relay. If your compressor coming on and pumping pressure that much to drain your battery, you do have a serious leak somewhere and as Skylaw indicated, you need to find it. I think if you put your ear close enough on each side, underneath, you just might hear where it's leaking from...
deucer is offline
post #9 of 12 (permalink) Old 09-26-2011, 05:43 PM
eric242340's Avatar
Quoted: 307 Post(s)
Relay location;
ERIC.
post #10 of 12 (permalink) Old 10-10-2011, 12:01 AM
Date registered: Dec 2009
Vehicle: 200 S500 W/144K miles
I had the same problem exactly. Firstly the battery tests can show its good when its really not so good. Secondly the thing that fixed my car is that the computer modules in the trunk were removed and cleaned and reconnected. Supposedly maybe from rain, water got in there and by removing and cleaning and reinstalling it solved the drain.
Good luck
1973 Porsche 911 RSR Project
1991 GMC Syclone
2000 Caddy Esc
2000 Benz S500
ArtisticEnt is offline
    1991 300sl hard to start after sitting for a few days SailawaySG R129 SL-Class 1 09-17-2009 12:38 PM
    Rough Idle After Sitting for Few Days DMensik W203 C-Class 6 08-08-2009 09:37 AM
    Loosing my MIND!!! Battery dead after 3 days of sitting. billabongo W220 S-Class 11 05-03-2008 12:47 PM
    Will Headlights if left on Turn off Before the Battery Dies? MiamiMerc General Mercedes-Benz 4 05-16-2007 09:01 PM
    Engine Noise after sitting a couple days charris R170 SLK-Class 7 08-22-2004 06:58 PM
