2000 S500 passenger seat & window not working - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-14-2011, 01:56 PM Thread Starter
Date registered: Aug 2011
After a bad rain my passenger seat controls, switch illumination, automatic door closer and power window stopped working. I have tested all the fuses and they are all good. I removed the door panel and removed the switch module and opened it and found no signs of water damage. Where else should I look? Any help is appreciated.
jimp88 is offline
post #2 of 10 (permalink) Old 08-15-2011, 01:58 AM
Terry_Tibbs's Avatar
Date registered: Jul 2011
Vehicle: 2004 W220 S320CDI
Quoted: 4 Post(s)
Fuse?
XFactor: Where the bewildered are wheeled out to be sniggered at by multi millionaires.
Gone:
2005 Range Rover Vogue
Terry_Tibbs is offline
post #3 of 10 (permalink) Old 08-15-2011, 08:38 AM
Vehicle: 2002 s500, 2004 S500 fourmatic
check the passenger floor....did the water get to the rear SAM?
tower is offline
post #4 of 10 (permalink) Old 08-15-2011, 02:47 PM Thread Starter
The front & rear mats were damp but not flooded. What and where is the SAM? Is it something I can check and fix? Thanks.
jimp88 is offline
post #5 of 10 (permalink) Old 08-15-2011, 02:48 PM Thread Starter
Is there a fuse under the front passenger floor? Is it under the seat or in the foot area?
jimp88 is offline
post #6 of 10 (permalink) Old 08-16-2011, 04:32 AM
If memory serves, there are a few SAM's through out the car. They interface to the data buses so control alot of the equipment. The one I'm thinking of is under the rear seat fuse panel and was subject to numerous claims when the drain in the engine compartment (biggish box in front of the wipers passenger side) plugs with debri and overflows directly into the vehicle. Search the site for other posts related to "flooded" vehicles.
tower is offline
post #7 of 10 (permalink) Old 08-16-2011, 05:22 AM
eric242340's Avatar
Quoted: 300 Post(s)
Your profile is not complete which makes it rather hard to give exact answers, so I will have to assume some things. If this is a left hand drive then the rear sam and fuse box is under the rear seat on the passengers side. In the rear footwell you can simply pull out the little floor light lense and behind this is the fuse box. To get to the SAM, Signal Acquistion Module you will have to remove the lower part of the seat and there is a lot of electrical equipment in there also the phone module is in there.
ERIC.
eric242340 is offline
post #8 of 10 (permalink) Old 08-16-2011, 09:30 AM
Date registered: Dec 2010
Vehicle: W220 2000 S430 Delivered to AU
Just in case you're about to wonder :
To get the rear seat out is meant to be quite simeple. I'm about to duck out and try it myself.
I just read there are some push in buttons / tabs on the bottom of the seat on either side. Simple push them in on each side and it's meant to come out quite easily.
I need to get in there in an attempt to find the phone unit that was just mentioned.
Also the VIN in .au cars is inside that rear compartment. Luckily someone at licensing knew that otherwise it would have taken me forever to find the metal plate to prove the papers matched!
andyshack is offline
post #9 of 10 (permalink) Old 08-16-2011, 01:15 PM
Date registered: Nov 2010
Vehicle: 2000 S500
Most likely the Door Control Module (DCM) i had the same symptoms after i got my tints done. I check and realize the DCM had gotten wet
This also might help http://www.benzworld.org/forums/w220...side-door.html
ScLass301 is offline
post #10 of 10 (permalink) Old 08-16-2011, 04:07 PM
Date registered: Nov 2009
Vehicle: 2004 S430
I Second the DCM (door control module) being the issue, i had to get it replaced after having my windows tinted also. Same symptoms too the passenger window and seat did nothing.
2004MBS430 is offline
    2000 S430 Passenger Window Stopped Working Mark2474 W220 S-Class 5 08-08-2011 09:54 PM
    Passenger Side Window Not Working QuangsBenz W124 E,CE,D,TD Class 8 11-03-2007 07:36 AM
    Passenger side window(s) not working CoreyH R/C107 SL/SLC Class 13 09-02-2007 11:47 AM
    passenger window not working 240D telletubby Vintage Mercedes-Benz 0 05-04-2005 11:09 AM
    my rear passenger window not working ??? Guest (MBNZ) W201 190-Class 5 04-18-2002 07:34 AM
