Another Tire Pressure warning light question - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-23-2011, 10:09 PM Thread Starter
Date registered: Apr 2011
Vehicle: 2004 S500
My Yellow tire pressure warning light is ON, plus the "Tire press....reactivate" page is on. Every time I start the car, have to press "R" to skip the page.
I've checked the tire pressure manually and is OK. Read quite a bit regarding this subject...
Questions:
1) How to individually check the sensor on each wheel?
2) How to "Reset" the yellow warning light?
3) How to reset the "Tire press.....reactivate" page so it doesn't come on every time the car is started?
Don't Lift is offline
post #2 of 5 (permalink) Old 06-24-2011, 06:36 AM
mjd
mjd's Avatar
Date registered: Aug 2008
Vehicle: 94 E320 Sportline sedan 86 190E 2.3 16V sedan 04 S430 Sport
Quoted: 2 Post(s)
Sounds like your TPMS sensors in your wheels have reached thier service life... given your model year listed (2004) - and if the sensors have not been previously replaced, the batteries are dead/dying.
I picked up my 04 in January this year and had the same issue, two of my TMPS sensors had completely dead batteries, the other two had very low voltage - i.e. almost dead. Service life according to MBZ for these sensors is about 4-5 years, so your well beyond that for original sensors.
If your sensors are still sending signal any Discount Tire or NTW/NTB can check to see if the sensors are working (your systems has the 315MHz BTW, NOT the 433MHz) So they can pull thier handheld scanner out to see at each wheel if the sensor is sending signal.
Also, untill the system is functional again, you will have to deal with pressing reset to get the error message to go away. It happens at start-up, and then about 10 minutes later - but after the 2nd notification (and your press reset again) the error message will not return until you shut down and restart your car, so for longer drives it wont annoy you multiple times at least.
Most tire shops can get you the Beru aftermarket replacement TPMS's (~$120 each), unless you just WANT to spend ~$300 each for the MB ones at the dealer.... either way Beru makes both.
I waited until I needed/wanted new tires and got all new sensors and tires installed at once, I did not mind pressing reset for a few weeks, but yeah... it can get annoying.
mjd is offline
post #3 of 5 (permalink) Old 06-24-2011, 02:37 PM Thread Starter
Vehicle: 2004 S500
Thanks mjd, will give Discount Tire a call.....
My Yellow Tire pressure warning light is ON all the time, a bit annoying !
Remember reading somewhere in the forum someone "Reset" that yellow warning light, for the mean time, sure would like to find out how to kill that warning light.
For all the troubles and $$, I just might opt to disable the whole TPMS.
$300 a pop at the stealer is insulting, even $120 is a rip off ! Oh well...it is a Benz !
post #4 of 5 (permalink) Old 06-24-2011, 03:22 PM Thread Starter
Vehicle: 2004 S500
Can a regular simple OBD-II scanner turn off this yellow tire pressure warning light?
post #5 of 5 (permalink) Old 06-24-2011, 07:34 PM
Date registered: Jan 2010
Vehicle: 2000 and 2003 W220 S500
I would doubt it...check to see, Pepboys or Autozone should be able to do it for free. Usually if the reader can read the fault, it can erase it and if it can't read it, it can't erase it.
Gabby07621 is offline
    low tire pressure warning light zak W164 M-Class 8 12-15-2016 05:08 PM
    Tire Pressure Warning - E350 brad__brown W211 E-Class 9 11-11-2013 08:44 PM
    Correct Tire Pressure Warning lucky_kid W204 C-Class 8 12-15-2010 07:28 AM
    Tire Pressure Warning Came on...need help Luke! 5IVE The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 12-04-2007 09:18 AM
    Tire Pressure Warning System Jörg W163 M-Class 6 03-22-2002 05:39 AM
