Occasional ESP / BAS error messages - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-18-2011, 06:06 AM Thread Starter
Date registered: Jun 2009
More frequently now, my vehicle instrument cluster will display two very annoying messages...
BAS : Brake Assist Error
and
ESP : Electronic Stability Error
I'm not sure what these are but if I turn off the car and re-start, the problem goes away. Anyone have suggest what I can do to fix this problem? My car has no problems at all, OBD2 does not produce any errors.
tabocat is offline
post #2 of 13 (permalink) Old 05-18-2011, 06:51 AM
mjd
mjd's Avatar
Date registered: Aug 2008
Vehicle: 94 E320 Sportline sedan 86 190E 2.3 16V sedan 04 S430 Sport
Quoted: 2 Post(s)
Hey Tabocat, have you tried the ESP re-sync procedure yet? There is a post in the encylopedia sticky under the resetting procedures... but basically you turn your steering wheel lock to lock a couple of times to re-sync the ESP system. Here is the post:
Synchronizing ESP (ECU):
If the power supply was interrupted (battery disconnected or empty), the BAS/ESP malfunction indicator lamp may be illuminated with the engine running. Turn steering wheel completely to the left and then to the right. The BAS/ESP malfunction indicator lamp should go out. For more on resetting the entire ECU, see http://www.benzworld.org/forums/w208...procedure.html.
mjd is offline
post #3 of 13 (permalink) Old 05-18-2011, 07:10 AM
eric242340's Avatar
Quoted: 312 Post(s)
and
Have the battery and charging system checked first of all and a diagnostic test to read the fault codes and then clear the fault codes.
In this instance there may not be any fault codes as it appears to be soft fault/event codes and once the ignition is switched off the code is cleared.
ERIC.
eric242340 is offline
post #4 of 13 (permalink) Old 05-19-2011, 06:57 AM Thread Starter
The battery is new, and I never had a problem with the alternator as all electronics are running fine. I will try the turn left and turn right trick, but not sure how that would fix the problem...
tabocat is offline
post #5 of 13 (permalink) Old 05-20-2011, 04:55 AM
Date registered: Oct 2008
Vehicle: S500 (W220) 2001
I had a similar issue.
Turned out to be the front right speed sensor.
Ive posted here about it.
If you have a faulty sensor, ABS and BAS cant function as they rely on the speed of all 4 wheels to stop you skidding etc.
My errors flashed after driving 30 mins or so. Just take care when braking in the wet.
Cost me Around £70.
I might be totally wrong but i did have the same error and turning engine off and on resets it.
1996 C200
2001 S500
2003 S500L
smackdog is offline
post #6 of 13 (permalink) Old 05-20-2011, 07:43 AM
daisound's Avatar
Date registered: May 2008
Vehicle: W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
smackdog,
As you encountered the speed sensor fault, what code has been show up on the error scan ?
500SEC 1984 retired at 192K
Porsche 928S GT 1984 (euro) retired at 243K
daisound is offline
post #7 of 13 (permalink) Old 05-20-2011, 01:40 PM
Sorry chief, but my OBDII sensor is a cheap £25 one.
Only gives engine faults. So dont know.
It was my mates garage and when he plugged in his box of tricks
front right speed sensor got logged.
But a quick search of google threw up this.
C0040 - Right Front Wheel Speed Circuit Malfunction
from
OBD-II Check Engine Light Trouble Codes
1996 C200
2001 S500
2003 S500L
smackdog is offline
post #8 of 13 (permalink) Old 05-24-2011, 01:40 PM Thread Starter
Smackdog, how did you know which speed sensor is the problem, left or right?
tabocat is offline
post #9 of 13 (permalink) Old 05-24-2011, 11:17 PM
The OBD2 sensor at the garage picked it up.
1996 C200
2001 S500
2003 S500L
smackdog is offline
post #10 of 13 (permalink) Old 05-25-2011, 02:00 AM Thread Starter
Did you change the speed sensor yourself? It sounds like an easy DIY...
tabocat is offline
Disconnected Battery, now ESP, BAS, AIRMATIC error messages tabocat W220 S-Class 9 11-03-2013 04:42 PM
2003 ML55 More Extensive BAS ESP Error Beast ML55 W163 M-Class 24 10-30-2010 08:51 PM
Help! ESP/BAS error on my 98 e55 projectG W210 E50 AMG, E55 AMG 8 07-29-2010 11:01 AM
ABS ESP BAS messages OverEngineered W210 E-Class 23 04-29-2010 01:48 PM
2002 G500 SRS, BAS and ESP failure messages Ken Olendzki G-Class 13 05-30-2002 06:45 AM
