S430 windshield washer inoperable - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 04-22-2011, 01:07 PM Thread Starter
VMAX7's Avatar
Vehicle: 2000 S430, 2000 S500 Both Brilliant Silver!
Quoted: 5 Post(s)
Unhappy S430 windshield washer inoperable
Hey guys, my 2000 S430's windshield washer is inoperable. When I push on the knob on the left-hand side of the steering column, nothing happens, only the wipers work, but the motor to spray water on the windshield does nothing.
I pulled the fuse and disconnected the battery but it still does not work.
Does anyone have experience on how to fix this issue?
S430 @ 275,000+miles
S500 @ 144,000+miles
Above 130mph
You got a Silver 220 or 215? Join my FaceBook page!
https://m.facebook.com/groups/318943928290331
VMAX7 is offline
post #2 of 14 (permalink) Old 04-22-2011, 01:44 PM
mrelbe's Avatar
Date registered: Jul 2004
Vehicle: 91 300SL with Pano Top, 04 S500, 2015 Tesla Model S
Quoted: 76 Post(s)
Tracing electrical stuff on these is a tough one. At the stalk end is the steering column module with electronics in it.
I suggest finding the connector at the washer pump and check for voltage there first.
91 300SL with Pano Top, 2014 Tesla Model S P85D Ludicrous
formerly 1980 450SL, 1990 560SEL, 2004 S500
Black Fuzzy Dice Gang Member
http://www.benzypalooza.com/
mrelbe is offline
post #3 of 14 (permalink) Old 04-22-2011, 08:01 PM
mjd
mjd's Avatar
Date registered: Aug 2008
Vehicle: 94 E320 Sportline sedan 86 190E 2.3 16V sedan 04 S430 Sport
Quoted: 2 Post(s)
washer pump could be clogged or just DOA and needs replaced. It is easy to get to the pump (behind passenger headlight assembly) and is simply mounted into a gromett so it is easy to pull out and test.... you will just lose all your washer fluid when you pull it out so dont do it in the garage unless you have a catch pan underneath.
mjd is offline
post #4 of 14 (permalink) Old 04-22-2011, 09:30 PM
Date registered: Feb 2008
Vehicle: 2004 (w220) S500 & 2001 CLK320 Cabriolet V6 3.2 L
Quoted: 5 Post(s)
I had same issue
I took 2 alligator clips to the windshield pump with 12 volts and nothing happened.
Motor shot.. autohauz az had new one for like $34.00
It is literally plug =n= play
Disconnect power connector & pull straight up.. Then remove the hose
reinstall opposite of removal easiest repair on this car
poptopclk is offline
post #5 of 14 (permalink) Old 04-24-2011, 07:40 AM
dlynch4008's Avatar
Date registered: Apr 2008
Vehicle: 2000 MB S500 and a 2009 Kia Optima
do yourself a favor... if you have to remove or replace the pump (probably), replace the grommets at the same time. This will save you from going in twice as the grommets are as old as the pump, and they do dry out. Pulling the pump may cause the grommet to leak as well.
dlynch4008 is offline
post #6 of 14 (permalink) Old 04-25-2011, 07:42 PM Thread Starter
VMAX7's Avatar
Quoted: 5 Post(s)
Thanks guys for the replies!
I'll tackle this, i'm on the second washer reservoir anyway due to my brother's incompetence ending up breaking one of two plastic nozzles, so i'll get the part and toss it in.
Above 130mph
VMAX7 is offline
post #7 of 14 (permalink) Old 04-25-2011, 08:07 PM Thread Starter
VMAX7's Avatar
Quoted: 5 Post(s)
Alright so I removed the pump from the reservoir which took about 5 minutes making sure not to break anything, cleaned the pump as bet I can, blew through both ends (air escaped with velocity) so I know it's not clogged...
So i'll order a new pump and grommet tomorrow and snap it in.
Here's some photos
Above 130mph
VMAX7 is offline
post #8 of 14 (permalink) Old 04-25-2011, 10:50 PM
Quoted: 5 Post(s)
I have spare reservoir for the S class msg me if you want it for $50.00
I thought it was bad & it was a leaky pump fitting so have extra one taking up space
post #9 of 14 (permalink) Old 05-14-2011, 04:13 PM Thread Starter
VMAX7's Avatar
Quoted: 5 Post(s)
My reservoiir is fine poptop, thanks for the offer tho.
I just got around to ordering the pump, will post pics of install, thanks for all your help!!!
Above 130mph
VMAX7 is offline
post #10 of 14 (permalink) Old 05-15-2011, 08:45 AM
mugur's Avatar
Date registered: Mar 2008
Vehicle: 2012 S550 Bi-Turbo 4Matic
Quoted: 8 Post(s)
Don't forget about grommet pictures too!!!
2003 S500 RWD bought at 105,000 miles sold in 2013
2012 S550 AWD bought at 106,000 miles in 2016
[/I]
mugur is offline
    windshield washer Beverly Sharp W201 190-Class 12 11-26-2010 11:25 AM
    Windshield washer paulf124 W211 E-Class 0 03-09-2008 06:05 AM
    windshield washer kdude87 W210 E-Class 4 01-20-2008 10:43 PM
    Windshield Washer baker462 Vintage Mercedes-Benz 1 02-07-2007 06:49 AM
    Windshield Washer alfredgee W123 E,CE,D,CD,TD,TE Class 3 02-18-2005 04:25 AM
