Hi everyone ☺
Today I decided to replace my drive belt idler. It was making rattling noises. Only 20 min it took to replace. Easy DIY job. I included photos as well.
Before you start removing belt, make droving how belt goes around all pulleys, pumps etc.
As you can see in first picture, that is my old and tired drive belt idler. Grease is all over idler and bearing make some noise.
Second picture:
I used ratchet with ev10 trx socked to move pulley up and remove belt.
Third picture:
I used flat screwdriver to remove cap and I used 50trx socket to remove long bolt.
Fourth picture:
New idler installed. As you can see bolt is long and on V8 and V12 engines you may need to remove radiator fan.
When idler installed now you can put new drive belt on. First, put belt around all pulleys and pumps and then use ratchet and ev10trx socket to lift up idler pulley and put belt on.
Fifth picture:
I started engine and everything is working fine, but after few seconds I discovered that this thing makes some kind very weird noise (I thought that belt idler was making). This noise was even before I replaced belt idler. Can anyone please tell me what is this thing (part no.A1122370240) and why this thing makes that rattling noise? And how is possible to get rid off this noise.
I hope that this photo DIY gonna help someone to do some work on they beloved Mercs ☺
Second picture:
Third picture:
Fourth picture:
Fifth picture:
