Keyless Go does not lock the doors - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-25-2011, 11:13 AM Thread Starter
Date registered: Jul 2010
Vehicle: S430-2002
Keyless Go is not working properly, unlocks the door, da boot, but when I leave the car and I lock the doors does not work ..
jucemel is offline
post #2 of 14 (permalink) Old 03-26-2011, 07:44 AM
eric242340's Avatar
Quoted: 295 Post(s)
Have you tried the microswitch lock on all the door handles? It may be the switch on the drivers door is faulty.
ERIC.
eric242340 is online now
post #3 of 14 (permalink) Old 03-26-2011, 08:24 AM Thread Starter
Vehicle: S430-2002
ERIC Thanks for answering, if I tested the 4 micro shooters and none works, I have 2 more targetas both electronic and does not work. Do you think it can be.
jucemel is offline
post #4 of 14 (permalink) Old 03-26-2011, 08:33 AM
eric242340's Avatar
Quoted: 295 Post(s)
Test the microswitches first as they are a common failure point. And I do not understand targetas?
ERIC.
post #5 of 14 (permalink) Old 03-26-2011, 08:36 AM Thread Starter
Vehicle: S430-2002
ERIC Mister sorry I'm using a translator I want you to know I have two Keyless Go and both present the same problem. Can you help me resolve this situation. Thanks
jucemel is offline
post #6 of 14 (permalink) Old 03-26-2011, 08:42 AM
eric242340's Avatar
Quoted: 295 Post(s)
I understand better now, use one keyless go card/key and keep the other one away from the car as two together interfere with each others signal and try to lock the car using the tiny button on each door.
ERIC.
post #7 of 14 (permalink) Old 03-26-2011, 09:01 AM Thread Starter
Vehicle: S430-2002
Let's see if I understood, I have to leave a card in the car and the other have her out of the car and there trying to close the small button on each door.
Escuchar
Leer fonéticamente
jucemel is offline
post #8 of 14 (permalink) Old 03-26-2011, 09:29 AM
eric242340's Avatar
Quoted: 295 Post(s)
Escuchar
Leer fonéticamente
Not quite got it yet, one card you leave at home. One card near the car and test all four buttons for locking.
ERIC.
post #9 of 14 (permalink) Old 03-27-2011, 06:49 PM Thread Starter
Vehicle: S430-2002
Mr Eric followed all the advice you gave me, even I put new batteries in the cards, nothing worked, is that there is a fuse to the end, I hope you continue thinking about my problem. Thanks
jucemel is offline
post #10 of 14 (permalink) Old 03-27-2011, 07:05 PM
eric242340's Avatar
Quoted: 295 Post(s)
Can you start the engine with the keyless go start on the transmission lever? If you can then the problem is not the KG card but the central locking system itself.
ERIC.
    All doors lock, except for one jvmaxime W140 S-Class 10 10-03-2010 07:51 AM
    W210 Rear doors unlock with keyless entry but does not lock. henry_desmond W210 E-Class 1 07-31-2010 01:54 PM
    keyless go open for both doors? // supercharger rough engangement tubaprde R230 SL-Class 3 12-22-2009 12:13 PM
    keyless door lock problem evilzee28 W124 E,CE,D,TD Class 3 01-11-2008 12:00 AM
    Keyless go door lock problem asodergren General Mercedes-Benz 5 01-02-2008 09:10 AM
