Car is absolutely all over the road. - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 10-07-2010, 11:59 PM Thread Starter
Sherlock SEL's Avatar
Date registered: Aug 2007
Vehicle: S500/500SEL/300E
Exclamation Car is absolutely all over the road.
My 2000 S500 is absolutely all over the road. I have 186k on it. It is becoming a huge issue. I am constantly correcting for the sway. My front sway bushings are out (I believe) because I get the clunk noise over bumps. Is that was is causing my car to drive so poorly? Between this and the transmission mount going and now the car dying I am " " close to getting rid of it. Can someone help me out?
Sherlock SEL is offline
post #2 of 17 (permalink) Old 10-08-2010, 11:44 AM
Date registered: Jul 2008
Vehicle: 2004 Mercedes-Benz S55 ///AMG, 2006 Mercedes-Benz E350
Quoted: 2 Post(s)
Sounds like control arm, thrust arm bushings have had it with their useful life on your car with 186K miles. Time to have your mechanic take a look and replace them. An independent mechanic will probably do it at half the cost of an MB dealer for these items.
Also, check for anything unusual on the tires, i.e warped, lug nut missing, just in case.
Good luck !
Klaus9000 is offline
post #3 of 17 (permalink) Old 10-08-2010, 07:18 PM Thread Starter
post #4 of 17 (permalink) Old 10-08-2010, 09:57 PM
daisound's Avatar
Date registered: May 2008
Vehicle: W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
If your car is all over the road that means your tie rods are gone. There are inner & outer tie rods. Hope your steering rack is OK. Your upper and lower ball joints needs to be replace too. How is your airmatic system ? Replacing all the things will cost as much as 2 thousands even you DIY.
500SEC 1984 retired at 192K
Porsche 928S GT 1984 (euro) retired at 243K
daisound is offline
post #5 of 17 (permalink) Old 10-09-2010, 10:18 AM Thread Starter
My airmatic is fine.
Ball joints plus tool are $150
LCA's are $210
Tie rod kit (inner and outer) is $110
Sway bar end links are $80
So thats $550. Which is doable and I knew when I bought the car (for $6,000) that it was going to need a couple thousand in work. What I am asking is are the link provided and the parts listed the correct parts to fix the problem?
post #6 of 17 (permalink) Old 10-09-2010, 11:38 AM
daisound's Avatar
Never buy parts from ebay. That is big "IF". Go to AutohausAZ.com. very dependable and reliable parts from OEM or similar german supplier. ebay will sell you china replica parts. Tools can be buy from ebay to save few $.
daisound is offline
post #7 of 17 (permalink) Old 10-09-2010, 12:48 PM Thread Starter
Noted. It appears that AutohausAZ.com is actually only a tiny bit more expensive then ebay anyway.
So I will need:
Tie Rod Pair
Pair of LCA's
Lower ball joints
Sway bar bushing end links
Is that it? Thanks for your help.
Also the lower control arms come with ball joints does that mean I don't need to buy lower ball joints? Or are they 2 separate ball joints? I'm confused if you couldn't tell.
post #8 of 17 (permalink) Old 10-09-2010, 01:44 PM
daisound's Avatar
Thrust arm comes with ball joint & bushing. $125 ea. Control arm only come with the joint attach the strut, sway bar link. The lower ball joint HD series will be $46. Tie rod comes with ball joint. Looks like you are missing the Thrust arm on your list. Post your DIY results later.
daisound is offline
post #9 of 17 (permalink) Old 10-09-2010, 02:16 PM Thread Starter
So let me get this straight; I need a:
Pair of Thrust arms with Balljoint and Bushing $250
2 Lower Ball joints (HD) $92
Tie rod set w/ whatever it comes with.
Sway bar links
AND the LCA's @ $250 for the set?
Will I be good for another 75-100 thousand miles after all this stuff?
post #10 of 17 (permalink) Old 10-09-2010, 08:54 PM
daisound's Avatar
Lower ball joint should be good for 75-100K miles. That will definitely get you start. But there are also upper control arm and double wishbone that attached to the front wheel axle. I can not guess what you have to replace. You should get the dealer to tell you exactly what you need at this point. It is not wise to replace all the front end components. You may have a bad rack & pinion steering system, even replace the inner & outer tie rod end may not help.
daisound is offline
    Best off road car? neilmegh G-Class 11 01-19-2009 05:22 PM
    Absolutely Must Get Rid of Car MorrisTigerson69 W126 S,SE,SEC,SEL,SD,SDL Class 56 02-24-2008 08:27 PM
    Smart on-road, off-road car? Corkscrew smart 0 04-09-2006 11:12 PM
    Absolutely horrible experience with a Starmark car. alchase@covad.net R170 SLK-Class 12 03-31-2004 08:33 PM
    OT What the absolutely worse car you've ever driven (old/new) - pls post on headline :-) Max (GR) R170 SLK-Class 13 03-09-2001 01:03 PM
