how to clean clogged windshield washer nozzels?? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 08-26-2010, 04:07 PM   #1 (permalink)
milin1609's Avatar
Date registered: Oct 2006
My 2001 S430 has two completely clogged windshield washer nozzels. Only the passenger side works. King of a driving hazzrd. I tried to find past threads on it, but couldn't found any. Can someone advice, how to clean these clogged nozzels? Thanks in advance.
milin1609 is offline   Reply With Quote
Old 08-26-2010, 06:51 PM   #2 (permalink)
Date registered: Jan 2010
Vehicle: 2000 and 2003 W220 S500
Any idea what might have done it?
Sap?
Wax?
Tacos?
I'm guessing you've tried Windex, Targone, uhh eating the tacos on top of your spray nozzles. If not, try those first.
If those don't work, remove the hood liner to see if the lines are actually connected. They might have popped off and are now spraying the inside of your hood.
If they're connected, follow the lines and see where they might be broken. Poke them too, see if liquid is inside them. If not, blockage might be all the way through the reservoir.
Just start at the nozzles and follow the yellow brick road, it can only be a blockage, a loose line, or a broken line. Not complicated, just annoying.
Gabby07621 is offline   Reply With Quote
Old 08-29-2010, 07:58 PM   #3 (permalink)
Date registered: Aug 2005
Vehicle: 2003 S430 Sport Edition
The local MB Tech used a sewing needle according to the size of the nozzle to clean it. Be carefull when inserting it not to make a hole inside the nozzle. These can get clogged from dirt - wax - polish. When wash an wax always check it after drying or finishing detailing.
Good luck.
Eddie
Curacao is offline   Reply With Quote
Bookmarks
3 of 4 windshield washer sprayers clogged? doctorkaligari R170 SLK Class 12 08-14-2007 05:51 PM
How do I fix clogged windshield washer dispensers? USA Soccer W201 190 Class 6 07-10-2007 06:28 PM
Clogged windshield washer nibs AlanS W124 E,CE,D,TD Class 3 12-18-2006 11:26 AM
Replacement windshield washer nozzels Captain Scott Vintage Mercedes-Benz 0 07-22-2005 08:46 AM
Wipers, washer nozzels, headlight switch 1999valkyrie W124 E,CE,D,TD Class 2 01-20-2005 09:49 AM
