How do you reset Limp Home Mode - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 03-26-2010, 04:52 AM Thread Starter
Vehicle: 97' S320 & 00' S500
I need a bit of help please. I have a 2000 S500. I need to reset "Limp Home Mode" Last night I changed my front wheel bearings (inner and outer), and on the passenger side when I was lowering the vehicle I let off my hydraulic jack too quickly and the can dropped to the ground very quickly. On the test drive the car was in limp home mode with the dash light illuminated. I dont think anything is really wrong as the car was running fine before all of this. I have done this procedure on many vehicles including my older W123's, W126's, and my W140. The reason I changed the wheel bearings is I needed an alignment to correct for a slight pull and the mechanic told me that there was too much play in the bearings for him to align the car accurately. How do you reset this mode?
kcscout is offline
post #2 of 20 (permalink) Old 03-26-2010, 05:53 AM
eric242340's Avatar
Quoted: 311 Post(s)
If you have the diagnostic test equipment then clear the fault codes and as long as nothing is seriously wrong limp mode problem will go away.
ERIC.
eric242340 is offline
post #3 of 20 (permalink) Old 03-26-2010, 06:26 AM
Date registered: Jan 2008
Vehicle: 98 ML320 7 Seats, all options 01' S500
Quoted: 6 Post(s)
Is there a limp home mode light in 2000 S500? where is the light? Or you refer to the check engine light or you refer to the message on the display?
My experience on my other MB (ML320) to get out of limp home mode is to disconnect battery for 5 minutes. Worked twice so far. However, the dealer told me I just lucky...
idahombz is offline
post #4 of 20 (permalink) Old 03-26-2010, 06:28 AM
eric242340's Avatar
Quoted: 311 Post(s)
Disconnecting the battery does sometimes work, a bit hit and miss really. And there is no Limp mode light, usually the check engine will remain lit and the car is locked in second gear.
ERIC.
post #5 of 20 (permalink) Old 03-26-2010, 06:37 AM
Quoted: 6 Post(s)
exactly! Once I have to disconnect 3 times (then test drive 3 times) to get out of limp home.
Without drive the vehicle, how can I tell (from Dash or OBDII) that limp home mode is gone?
idahombz is offline
post #6 of 20 (permalink) Old 03-26-2010, 06:40 AM
eric242340's Avatar
Quoted: 311 Post(s)
Limp mode means the car will not shift above second gear so if it shifts normally then she is out of limp mode.
ERIC.
post #7 of 20 (permalink) Old 03-26-2010, 06:43 AM
Quoted: 6 Post(s)
correct! That's how i figure if my disconnect battery worked or not. My question is , is there any way to tell without driving. Thank you!
BTW what do you do in the donkey's home town?
idahombz is offline
post #8 of 20 (permalink) Old 03-26-2010, 06:45 AM
eric242340's Avatar
Quoted: 311 Post(s)
1, NO you must drive to understand if it is or is not.
2, Business partner and MB Tech
ERIC.
post #9 of 20 (permalink) Old 03-26-2010, 06:53 AM
Quoted: 6 Post(s)
Thumbs up
thank you! and enjoy!
idahombz is offline
post #10 of 20 (permalink) Old 03-26-2010, 07:58 AM Thread Starter
Will a Code Reader work
Will a standard OBD II Code Reader work, or do I need some special disgnostic equipment specifically for the MB.
kcscout is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Limp Home Mode MikaHakkinen R129 SL-Class 9 06-30-2011 06:43 AM
Why a reset (disconnect Battery) can have the truck get out of limp home mode? idahombz W163 M-Class 18 03-31-2010 12:43 PM
Limp Home Mode Andrzejek W202 C-Class 21 02-04-2010 08:48 AM
Limp Home Mode HELP eapen W210 E-Class 4 05-04-2009 05:27 PM
Limp home mode? rlbmd2006 W203 C-Class 0 08-27-2007 10:27 AM
