Originally Posted by TheBenZo Might be a hall position sensor? There is a cable under the seat that unwinds as it moves back. Does the bun work ok back and forth? |
Assuming bun is the bottom portion of the seat, that works fine all the way back and forth. It's just getting the whole unit to go back. I took a look under the seat, which I hadn't done yet, and there is a cable that comes out of the carpet, on the door side of the seat, sort of bicycle cable style, and it has slack in it. If that is part of the hall position sensor you mentioned and it is supposed to be taught to keep a measurement of where the seat is, then this is almost certainly the problem.
Any additional input on this cable is appreciated. Didn't look like an easy fix to track down this cable and replace it considering it disappears under the carpet.
