Harmonic Balancer Recall - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-29-2009, 03:36 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 44 Post(s)
Hello:
I have read through some posts on the forum, and in fact there is a recall for my car.
I called the local dealer, and they told me they checked "online" and that no recalls were pending.
BUT, but looking at the pulley, it does exactly what the recall mentions (wobbles).
Can someone provide me with the recall letter?
Does the bolt need to be replaced as well?
Thank you
R107
S320L1999 is offline
post #2 of 7 (permalink) Old 11-29-2009, 05:35 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 286 Post(s)
I traded my '00 several years ago and passed along all of my maintenance records, the recall letter, and the like to the new owner. I no longer have the document to send you. The documents sent out in the U.S. were sent under U.S. law, and would not apply to other countries.
You have obviously been doing your research; I applaud you for that. The problem with the harmonic balancer (also called a belt tensioner) was that it had two metal components joined by a rubber damper; the rubber damper would separate, and the metal sections would come apart. Searching my bookmarks, I was able to locate this informative post: http://www.benzworld.org/forums/gene...ey-points.html
The recall was only for certain VINs and it was to have the part inspected for certain identification numbers that are shown in the link above. If the part had the numbers, it was replaced. My particular car did not have the defective part, so it was not replaced. The information that your dealer is providing may be accurate; the actions taken by Mercedes (regardless of country) may not have applied to your vehicle.
I would not hesitate to have a tech look at your harmonic balancer to see if it shows any signs of separation, or other damage for which it should be replaced. (For other readers, if it looks OK, and if you are not experiencing vibration, it is likely OK - especially this long after manufacture). Because yours wobbles, I would replace it (though the wobble may not be caused by the separation problem that resulted in the U.S. campaign). Replacement of the bolt was not part of the recall notice I received, but your problem may be from wear of either the balancer's bearings or the bolt itself.
A search of the forum (and also MBWorld) will also reveal some DIY information on replacing the balancer with 3rd party "performance" versions. Those posts may save you some money (even if you used a stock balancer) if you wished to replace what you have for peace of mind.
I searched the U.S. NHTSA site for recalls and for technical service bulletins; that particular campaign was not listed. Office of Defects Investigation (ODI)
This response differs from my email response to you; I came across your post, which had more information than your email to me, after responding to your email.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 7 (permalink) Old 11-30-2009, 06:25 AM Thread Starter
Vehicle: W107 W113
Quoted: 44 Post(s)
Thank you very much for you very detailed reply.
Searching through other forums, I was able to located this PDF which addresses all the issues.
It seems, in fact, my car is not covered.
R107
post #4 of 7 (permalink) Old 11-30-2009, 06:48 AM
eric242340's Avatar
Quoted: 312 Post(s)
Just change it will ya
ERIC.
eric242340 is offline
post #5 of 7 (permalink) Old 11-30-2009, 01:55 PM Thread Starter
Vehicle: W107 W113
Quoted: 44 Post(s)
Ok, ok, shall be done!
R107
post #6 of 7 (permalink) Old 12-01-2009, 09:37 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 286 Post(s)
Thank you for posting that.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #7 of 7 (permalink) Old 12-01-2009, 02:52 PM
Date registered: Jan 2007
Vehicle: 2003 S55K, 2002 W220 S430 (RIP), 1999 W163 ML430, 2004 W230 SL500 Sport
No recall but on my ML430 It needed it, I didn't see it until the belts started squeaking at 50K miles
$380.00 parts/labor from an independent with a new serpentine belt now it has 71K miles
I notice that there are similiar engine issues that affect the 430.
wsy3benz is offline
Harmonic Balancer recall? sstomcat W163 M-Class 3 09-29-2007 08:28 AM
Harmonic Balancer Recall 247hoopsfan W210 E-Class 2 12-15-2005 11:17 PM
Harmonic balancer recall mclasser W163 M-Class 4 07-17-2005 10:34 AM
HARMONIC BALANCER RECALL jtorre1 General Mercedes-Benz 1 06-29-2005 03:32 PM
Recall for harmonic balancer 247hoopsfan General Mercedes-Benz 0 01-28-2005 12:19 PM
