Sun/Moon Roof Gasket/Seal ??
Has Any One Changed One Yet ?
Mine Is Starting To Peel The Top Layer Off.
Any Help ? It Looks Easy Enought
Thanks
Harley03joe
__________________ "You Can Pick Your Nose & You Can Pick Your Friends
But You Can't Wipe Your Friends On The Couch"
2002 M-Benz SL500 < SOLD
2005 M-Benz S 500 Silver/Silver Gut/
2003 Harley-Davidson 100th Anniversary Black/Silver
2000 GMC Sierra Short Bed Step Side P/U Truck Red
2004 Hyunadi XG 350 Great Car
According to ALLData, you first remove the wind deflector - should be a bar that pops up when the roof slides back. If there's a travel limit to it, work to disengage the limit stop, then lift on one side and press down on the other to detach the pivot pins.
Here are the instructions:
1 Remove wind deflector
2 Loosen screws (6)
3 Unscrew seal (1) from rails (2, 3, 4, 5)
CAUTION: Carefully pull seal (1) out of rail (2) because barbs are present on the rail
Installation
4 Push rail (2) up until the spacers (7) are against the roof and tighten screws (6)
5 Press seal (1) into rails (3, 4, 5) at the points marked with arrows with the grooves pointing up.
NOTE: Use lubricant
6 Install wind deflector.
W. Brian Fogarty
'02 S55 AMG (W220)
'92 300SE (W140) - sold
'76 450SEL 6.9 Euro #1164 - gone for parts
'76 450SEL 6.9 Euro #521
"Bond reflected that good Americans were fine people, and most of them seemed to come from Texas..." Casino Royale, Chapter VII
2 Loosen screws (6)
Installation
NOTE: Use lubricant
Thank You Wbrian
I Have Alldata Also, But I Was Just Wondering If Any One Done A Seal/Gasket Replacement Yet
But Thank You Very Much For The Info, I Know It Took Time To Look It Up
Thanks
Harley03joe
I also have some rust on one coner.
mine is 2002 s500
WOW Not Good At All.
I Hate A Car That Has Rust ,, It's The Same As Cancer You Never Get It All Out, I Really Hate To Here That About A $90,000.00 Car Its A Crying Shame
I'm So So Sorry That Is Really Sad
Harley03joe
