» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 11-16-2009, 08:09 AM   #1 (permalink)
Date registered: Apr 2008
AC fan noise in dash
Hi everyone,
I have fan noise from somewhere in the middle of the dash when I have the AC on. It never shows up when I mentioned it to the SA at the dealer. Since they can't find it then they will not fix it. I noticed that the fan noise comes only when I use the AC, never without AC. It is very irritating on long trip because you can hear it quite loud with the AC cycling on/off.
Car is 2006 S500. Any suggestions for what to fix? Thanks.
tn52 is offline   Reply With Quote
Old 11-16-2009, 11:49 AM   #2 (permalink)
Date registered: Jul 2008
Vehicle: 2004 Mercedes-Benz S55 ///AMG, 2006 Mercedes-Benz E350
I was told by my SA that the entire dash needs to be disassembled to get to the "air box" and fans. A very time consuming job invloving several hours of labor but your car is probably still under warranty.
When I have issues like this (I see a problem, Dealer says they can't find it), I ask to go for a drive with the SA or Shop Foreman. It has worked every time since you can point out exactly what it is during the test drive.
Good luck!
Klaus9000 is offline   Reply With Quote
Old 11-16-2009, 01:42 PM   #3 (permalink)
Thanks for a quick reply. I would like to add that I did a couple test drives with the SA and my car did not show any AC fan noise. The noise is more likely to show up on long trips (4-5 hrs) and if it does, then it is quite loud. I can turn off the AC for a few minutes and when the AC was turned back on, it will be good for another hour or two... I just don't know how many fans do we have in the dash or just one? Obviously, it is not a common problem.
Old 11-24-2009, 12:57 AM   #4 (permalink)
Date registered: Nov 2009
Hi,
It can be the ambiental sensor fan what you hear, the noise can be from the dust that is covering the sensor, we usualy celean the sensor and the problem is solved but this is the procedure at Renault, Honda, and Peugeot.
Lucian Girbaciu is offline   Reply With Quote
Old 12-12-2009, 01:57 PM   #5 (permalink)
ackee911's Avatar
Vehicle: Mercedes S500L W220
Had the same problem, turned out to be the AC compressor or something like that-its located under the dash on the passenger side. (I'm RHD).
Worked for me
ackee911 is offline   Reply With Quote
Old 12-13-2009, 08:11 AM   #6 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic, 1978 450SL
The ambient air sensor that Lucian was talking about above is called the aspirator motor, a tiny fan motor that blows air past the cabin temperature sensors. One is located in the passenger side A/C control panel, and the other in the overhead panel (where your overhead lights and moon roof control are). They are behind small grilles.
The location from which the noise is coming can be very confusing to the driver. I would have these checked, with a stethoscope if necessary, before tearing the dashboard apart.
2005 S500 4-Matic
with Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 12-17-2009, 10:37 AM   #7 (permalink)
gmund's Avatar
Date registered: Mar 2008
Vehicle: 2006 S430 4-Matic, Silver/Black
According to my service advisor, the electronic buzzing I hear in my dash is from the aspirator motor. Said it was normal, which to me seems strange to have this noise on an $80,000.00 car.
gmund is offline   Reply With Quote
Old 12-17-2009, 02:11 PM   #8 (permalink)
Skylaw's Avatar
I do not believe it is "normal" unless your hearing is especially sensitive. I don't hear mine at all, ever. They can be replaced - unfortunately, MB no longer sells the aspirator motors themselves; they come as part of more expensive assemblies. If you still have any warranty left, make them fix it.
Noise coming from Dash - Gets louder as fan speed increases croat W163 M-Class 3 10-26-2009 04:58 PM
Fan noise in dash 93sportline W201 190 Class 8 05-12-2009 06:30 PM
Dash Panel and Fan Short Circuit analystguy W126 S,SE,SEC,SEL,SD,SDL Class 4 08-08-2007 08:59 PM
Dash fan early 463. jorgenbg G-Class 6 02-22-2006 12:41 PM
89 300SE w/ no dash lights or blower fan???? Brythonic W126 S,SE,SEC,SEL,SD,SDL Class 3 03-13-2005 09:13 AM
