S430 TCM (transmission control module) - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-18-2009, 05:57 PM Thread Starter
Date registered: Jun 2009
Vehicle: MB S430
hi,
where is 2000 year S430 w220 Transmission Control Module
thanks...
sfinx is offline
post #2 of 8 (permalink) Old 10-18-2009, 07:52 PM
Date registered: Mar 2008
Vehicle: 2000 S430
It's under the hood, passenger side, near the windshield, in a covered compartment with several other computer modules, fuses,and relays.
There should be two connectors attached to the top of the module. The module should have a label on its side listing the part number (e.g. A022 545 50 32 SIEMENS).
joeburmeister is offline
post #3 of 8 (permalink) Old 10-18-2009, 08:40 PM Thread Starter
Vehicle: MB S430
thanks a lot, i was searching it inside the car under the glove box as russian service manual says
sfinx is offline
post #4 of 8 (permalink) Old 11-08-2009, 08:14 PM
Date registered: Oct 2009
Can I replace it by myself? one need reprogrammed at dealer,
nurmyrat78 is offline
post #5 of 8 (permalink) Old 11-15-2009, 08:06 PM
Vehicle: 2000 S430
I replaced my TCM with the exact same part number and my CEL went away and car was no longer in limp mode. I didn't have to reset nothing.
However, I had obtained a used TCM (not a new one) from a same model year vehicle. I believe if you replace your TCM with a new module then yes it has to be programmed by the dealer in order for the module to adapt to your car.
post #6 of 8 (permalink) Old 11-17-2009, 11:46 AM
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Joe is correct a new unit has to be programmed before it will work.
kyle21nluvnit is offline
post #7 of 8 (permalink) Old 07-13-2015, 08:17 PM
Date registered: Jul 2015
Need Help!!!
I need help!! How do you program the the TCM for 2000 Mercedes-Benz s430.
Ferman312 is offline
post #8 of 8 (permalink) Old 11-02-2015, 04:27 PM
Date registered: Oct 2015
Vehicle: 2001 s430
hi all ,
my TCM got water damaged and my independent mechanic told me that i need to replace it. he said that he can get the part already programed and we would just need to plug it in. the only issue is that is costs 1300 dollars.
a used one on ebay runs around 250. my question is if i buy it from ebay with the same part number do i need to program it or am i good to go ?
thank you
Mohamedali is offline
    Where is the Transmission Control Module - TCM - located on E320? Franasia W210 E-Class 4 08-20-2016 08:08 AM
    '03 E500 Transmission Control Module (TCM) Change burkett W211 E-Class 20 11-21-2014 01:04 PM
    WTB: 97 or Compatible W140 EGS Transmission Control Module (TCM) arcticrevolver For Sale/Wanted/Trade/Giveaway 1 10-24-2009 11:25 PM
    Location TCM transmission Control module C320 firebirder W203 C-Class 0 01-03-2009 07:58 AM
    '03 E500 Transmission Control Module (TCM) Change burkett W211 E55 AMG, E63 AMG 0 08-19-2008 07:36 PM
