» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 06-29-2009, 08:14 PM   #1 (permalink)
chibenz's Avatar
Date registered: Aug 2008
Vehicle: 02 S500
Transmission Work done. What you guys think
A Week ago I noticed little transmission oil leak around electrical plug area. Thought it would be easy and inexpensive fix but things turned out differently because of over tightened screw in the middle of connector plug, solution new electro module ( conductor plate ) and new connector.
Went to eurobahns auto repair (Indy) they charged me $525.00 including parts and labor for the following
1) Electrical connector plug replaced
2) Electromodule ( conductor plate) module replaced
3) Fresh MB transmission oil and filter change
After all the work transmission shifts smoother and no hesitation. I never got the idea why does MB say that transmission is closed system and no oil change or service needed. I am glad that I am good for another 40k or 50k.
chibenz is offline   Reply With Quote
Old 07-03-2009, 09:39 PM   #2 (permalink)
Date registered: Mar 2008
Vehicle: 2000 S430
That is not a bad price since the conductor plate alone is around $230 and the Tranny fluid is approx $80 (assuming they drained the pan as well as the transfer case - approx 7-8 quartz total) . Throw in the filter, and the pan gasket, connector, o-rings, magnet, etc, and $525 sounds reasonable.
However, did the shop overtightened the screw when they were inserting the new connector? So if that is the case, it was their negligence that resulted in you having to purchase a new conductor plate?
When I purchased the conductor plate from the dealer, they specifically warned me to NOT overtightened the middle screw since if i strip the thread, I would be looking to purchase a 2nd new conductor plate.
Since you had a leak, did you pull the transmission control module (passenger side fuse box) and check to see if any oil manage to work its way into the module?
joeburmeister is offline   Reply With Quote
What kind of work you guys do.....??? firstmb W164 M-Class 76 10-09-2007 08:27 PM
Do you guys do your own work? 1 BAD BURB W210 E50 AMG, E55 AMG 8 09-02-2006 01:28 AM
Guys, keep up the good work! tcp_ML500 W163 M-Class 2 06-13-2003 03:58 PM
Will this work on my ML? What do you guys think? RedDevil W163 M-Class 1 06-17-2002 07:04 PM
