» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 03-07-2009, 02:12 PM   #1 (permalink)
Date registered: Jan 2008
Vehicle: 2000 Mercedes S500 2002 Yamaha R6
Wiper balade size ???
I am not sure if my car has a right size blades to start wiht
Driver side 26"
Passenger side 28"
Is that correct ????
thanks
Ramunsa is offline   Reply With Quote
Old 03-09-2009, 08:12 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2003 S430 4Matic
It should be 27" all together.
2003 S430 4Matic
Owned:
2001 Audi A8L
2001 GMC Denali
1997 Audi A8
1995 BMW 325IC
1991 300E 4Matic
1997 & 1994 Landcruiser
1995 Range Rover LWB
2000 GMC Denali
1997 Discovery
1992 & 1987 Saab 900T Conv
1992 SVX
1991 BMW 750IL
1991 Mustang 5.0 LX Conv.
2000 Audi A6 4.2
2003 Cadillac Deville DTS
2004 Hummer H2 Black
2005 Hummer H2 White
2001 E430 4Matic
2004 Ford Expedition EB 5.4
2003 S430 4Matic
leeah is offline   Reply With Quote
Old 03-09-2009, 10:58 PM   #3 (permalink)
cool thanks for the info
Old 04-08-2009, 11:57 AM   #4 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic, 1978 450SL
Avoiding high prices for replacement blades for the W220 have been problematic in the past. The OE blades are 27" (690mm). The newer style blades (actually, Bosch Aero Twin blades) have commanded prices of up to $150 for a pair through dealerships.
I have in the past bought a 28" blade for the driver side, and a 26" blade for the passenger - since 27" blades are hard to find.
The last set of blades I bought were TRICO, similar in appearance to the Aero Twins - they were awful. They were flimsy and did not make good contact with the glass, leaving unswept areas. When I tried to bend them for better contact, they came apart. The Rain-X blades look sturdier, but I do not like the look of the mount; it is not as nice as the OE.
I came across this site, selling Bosch Aero Twins at a reasonable price: Mercedes Wiper Blade - 2005 Mercedes Benz S500 - AutoPartsWarehouse.com. These blades are supposedly the OE blades, packaged differently. Best part: Two blades are significantly less than dealer prices. And even better - Bosh offers a pair of blade inserts at a very reasonable price. I also came across a video on replacing the inserts, at YouTube - FLAT WIPER BLADE REFILLS, AEROTWIN BOSCH, AERO, NOT VALEO OR SWF OR VISIOFLEX.
And, in addition, my dealership has lowered its price to $66 for a blade replacement set.
2005 S500 4-Matic
with Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 04-08-2009, 12:43 PM   #5 (permalink)
Vehicle: 2005 S500 4matic Sport Designo
good info, thanks.
you happen to have a part number for the OEM replacement set?
on the inserts, there appears to be some sort of strange retaining clip. The stock inserts do not have this.
Also, whats the difference between the 3 bosch sets on the autopartswarehouse?
thanks.
OliverK is offline   Reply With Quote
Old 04-08-2009, 05:32 PM   #6 (permalink)
I saw one S500 later years not sure what year it had Michelin some kind of frame less blades looked very good.
Aero Twins isint it like $18 per blade at the wallmart ???
Old 04-09-2009, 02:34 PM   #7 (permalink)
Skylaw's Avatar
Originally Posted by OliverK View Post
good info, thanks.
thanks.
No, I don't have the number.
I'll know more about that clip when mine arrive.
One Bosch set is the older, non-Aero Twin blade set. The only thing I can imagine being different between the two sets of Aero Twins is the mount. Rain-X makes a mount that would fit both a hook-shaped connector, as well as a post mount. One of the Aero twins (probably listed for 2000- 2006 models) is probably like that. My OE Aero Twins have a mount only for a post, not a hook. My guess (and that's just what it is) is that the other set is shown for the 2002-2006 models and has a post mount only.
Old 04-09-2009, 02:36 PM   #8 (permalink)
Skylaw's Avatar
They may be; the site I gave the link for lists two for about twice that. Will have to check Wal-Mart.
Old 04-09-2009, 03:08 PM   #9 (permalink)
I ordered a set of inserts as well, so skylaw, you might be getting another set mailed to you if they suck. LOL.
Old 04-10-2009, 01:51 PM   #10 (permalink)
Skylaw's Avatar
Follow Up
My blade inserts arrived today; they were not for the Aero Twin blades, and they were not the part number shown on the web page. The inserts that arrived were for the older style blades; they had a molded-in metal backing. The Aero Twin inserts have no metal, they are rubber only.
I am returning them (and Auto Parts Warehouse's return procedure is a slow nightmare); the part number for the older style blades I received was 3 391 014 995. The part number for the 930mm (27 inch) Aero Twin insert is W0133-1718274 - which is shown on the website, and which they verified after consulting catalogs. AFTER 40 MINUTES OF DISCUSSION AND DESPITE SHOWING THEM THEIR LISTING ON THEIR WEBSITE, AUTO PARTS WAREHOUSE DOES NOT STOCK THE AERO TWIN INSERTS - only the blades. They could not answer why they show the proper part on their site, but do not stock it (apparently, it was not a back-order situation) and tried to sell me a whole set of blades.
In the event anyone can locate Aero Twin inserts, I went ahead and opened up my wiper blade; to make the video a bit clearer, see the photos below. The end cap is held on by two nipples that fit behind the metal mount (arrows). I found it easiest to insert a small screwdriver between the rubber on the front side of the blade, and the cap, lifting slightly; then removing the screwdriver blade and pushing hard against the back edge of the end cap. It pops off. It is only necessary to remove the upper end cap (the one that would be at the top of the windshield when wiping). The end cap is shown partially removed.
The next item not clear in the video was bending a retaining "spike" up to release the blade. The "spike" penetrates the rubber insert slightly to hold it in place. See the second picture. If you remove the lower end cap rather than the upper, you will not see this "spike" and the insert will not slide out. You can guess how I know that.
After all that, it would have been easier to just buy the darned things complete. But I'll buy from someone else. I don't mind a simple error, but I am furious that they tried to blame their website problem on me, and tried to tell me I ordered something I didn't (I ordered the only inserts on the page that were shown for my car, no other inserts were shown; and despite confirming the part number, they tried to tell me I ordered the wrong thing).
More research shows the 930mm (27") Aero Twin blades to be available through a number of other sources at under $40 per set - parts geek, drive wire, and others. Search by the Bosch blade part number, W0133-1617736.
WIPER BLADE SIZE Canadian ML W201 190 Class 1 10-21-2008 04:48 PM
Wiper size?? ajent420 W210 E-Class 2 06-08-2007 05:43 AM
Which Size Wiper Blade? biofuel W201 190 Class 2 10-10-2006 06:18 PM
Windscreen wiper size: 15 or 16 inch? Scottgs G-Class 4 10-24-2005 08:01 PM
Wiper size Lenny Satz R170 SLK Class 10 12-04-2001 10:36 PM
