» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 12-27-2008, 06:23 PM   #1 (permalink)
mers320's Avatar
Date registered: Feb 2008
Vehicle: 08 Mercedes s550 AMG 4matic, 02 Mercedes e320 4matic 55K,1980 benz 300D Auto. 1995 Benz e320 155K
Post 2000 s430 BLOWER MOTOR REGULATOR LOCATION??????????????
please help how do i get to the blower motor regulator in 2000 s430, where is it located?
and if any one had same problem as i have? my ac cotrol lights up but i can't get blower motor to blow i think it is blower motor regulator problem :confused:
mers320 is offline   Reply With Quote
Old 12-28-2008, 12:15 PM   #2 (permalink)
See the link below, more than you will ever want to know.
http://www.mercedestechstore.com/pdf...2010-30-02.pdf
rccmerc is offline   Reply With Quote
Old 12-30-2008, 07:45 PM   #3 (permalink)
mers320's Avatar
find it thank you problem fix
Old 01-01-2009, 09:40 PM   #4 (permalink)
Date registered: Aug 2008
Vehicle: 2000 S430
I'm experiencing the same problem in my 2000 S430.
About a week ago I heard a ticking sound from below the glove box for a few days, then the AC would not blow any air out whatsoever. After another day it came back on. It went out shortly after, then came back on again. It's been on since, but the ticking noise continues. Is this what you faced? And how did you repair it?
s430-bez is offline   Reply With Quote
Old 01-12-2009, 10:38 AM   #5 (permalink)
Date registered: Jan 2009
blower motor
Ticking noise from blower motor usualy brush contact on commutator /worn brushes/ partialy siezed motor, strip motor down clean it lube it, make sure theres enough carbon brush, put back together done it myself 2 year ago motor still running now, one thing to remember when putting plastic shroud on motor(white) make sure the cooling duct faces the brush area i made the mistake of putting it on wrong, it caused the motor to overheat and then the regulator would cut the supply until it cooled off again, easy job really.
paul murphy is offline   Reply With Quote
Old 01-12-2009, 05:37 PM   #6 (permalink)
MBS430's Avatar
Date registered: Oct 2005
Vehicle: 2000 S430
NHTSA Recall Campaign Number: 00V141000
Component: AIR CONDITIONER
Details: VEHICLE DESCRIPTION: PASSENGER VEHICLES. DUE TO AN INTERNAL DEFECT IN THE CIRCUITRY OF THE BLOWER MOTOR REGULATOR, THE REGULATOR MAY OVERHEAT.
Consequence: THIS COULD CAUSE SURROUNDING PLASTIC, INSULATION, AND WIRING TO DEFORM AND POSSIBLY MELT OR BURN.
Corrective Action: DEALERS WILL REPLACE THE BLOWER MOTOR REGULATOR.
Units Potentially Affected: 7100
Recall Initiated By: MFR
Date added to NHTSA datbase: 05/22/2000
MBS430 is offline   Reply With Quote
Old 01-20-2009, 04:13 PM   #7 (permalink)
mers320's Avatar
had to buy new blower motor assembly
now problem solved
apparently in w220 you have to change whole thing for some reason
cant replase one or other
Old 02-05-2009, 02:39 PM   #8 (permalink)
Vehicle: 2000 S430
paul murphy, great suggestion.
the dealership suggested it would cost me over $1200 to replace.
The pump works occasionally and sometimes not. Ticking noise is still present. I'm thinking your solution might work.
How would I go about accessing it and the steps to getting there?
Old 02-06-2009, 10:46 AM   #9 (permalink)
Start by removing upper footwell trims on passenger side a few screws nothing technical, this will expose fan assembly which has the fan resistor fixed to it, remove four more screws (these hold the fan to the foot well) (one screw at the rear of the fan is a bit awkward shine a torch up and you will see it) then lower fan down disconnect plug and that's it really. Spin fan by hand and listen for noises and feel for tightness, remove plastic shrouds/resistor and anything else that's easily removed, my motor was real tight due to water ingress, bearings had dried out, looking at the motor at the brush end you need to uncrimp the lugs on the end cap (a pair of side cutters will do) don't cut them off just bend them out the way and the end cap will come off exposing the brushes, give it a good clean and grease the bearings if your brushes are down to the metal you could try and make a pair out of a vacuum /hoover parts (easily modified) mine still had life in them but where sticking, as long as you have 5 or 6 mill left that will still fun for a long time, when your happy everything looks OK put it all back, two things to remember keep both brushes pulled back and kept back when your putting end cap on, then release them when cap is secure, other thing it to remember to put the plastic cooling duct from the brush area to the fan the right way take pictures if it helps, don't be put off by anything its not as hard as you might think, Paul m.
Old 02-09-2009, 02:44 AM   #10 (permalink)
Date registered: Jul 2003
Vehicle: S500 W220 - A190 W168 - SL320 R129 (SOLD)
Paul,
Hi. Thanks for your detailed description of how to gain access to the blower fan motor. When I tried I could not get to the Torx screws that hold the black casing for the blower fan motor. I found that some dashboard was in the way, I also had the glove box removed to no avail.
Am I missing something that allows me to get better access?
Also, I struggled getting into this footwell area in such a position to see properly.
Please advise and thanks.
Kevin
S500 Obsidian Black
A190 Silver
SL320 Silver - GONE
kevinj is offline   Reply With Quote
Sorry! Blower motor regulator? maxon W140 S-Class 10 03-10-2009 08:52 PM
1998 W210 E300DT Bad Blower Regulator or Blower Motor?? How to tell DieselNuts W210 E-Class 6 11-24-2008 09:58 AM
A/C Blower Motor Regulator rayracer W210 E-Class 1 09-07-2007 10:00 PM
blower motor or regulator??? 4maticinmedford W210 E-Class 4 08-11-2007 05:52 PM
Blower Motor Regulator aglasgow W210 E-Class 1 05-12-2003 10:56 AM
