» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 10-29-2008, 08:14 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
slotted vent in HVAC dash unit?
Im a bit confused.
On the passenger side of the dash HVAC unit, above the all off button, there is a slotted grille vent.
There is a noise emanating from this grille unit. A sort of rattling/buzzing. I was under the impression that this was the sampling fan for the climate control. Now Im reading that this sampling fan is up by the rearview mirror.
So, long story short, if it isn't the sampling fan, what is behind that slotted grille?
Thanks
OliverK is online now   Reply With Quote
Old 10-29-2008, 11:21 AM   #2 (permalink)
Date registered: Nov 2007
Vehicle: 2006 S500 4Matic
It is a sampling fan that needs to be replaced to eliminate the noise. There are two sampling fans, one where you describe and another overhead.
I just had my overhead unit replaced. FWIW, on the overhead unit, it used to be possible to replace just that fan, now the fan is integrated into the overhead unit and the entire overhead unit was replaced ($300 part from MB). It was done under warranty in my car so no $$ out of my pocket. I do not know whether the lower sampling fan can be replaced without replacing an entire circuit board.
bmurphywa is offline   Reply With Quote
HVAC Issue: side vent blows hot air w/ a/c use Raposka W202 C-Class 11 07-13-2009 08:41 AM
Delay when turning HVAC unit on. W140FTW W140 S-Class 5 03-19-2008 09:10 AM
A/C Dash vent problems BoRegards W124 E,CE,D,TD Class 7 08-14-2007 10:49 AM
95 C220 A/C vent on dash does not open, why? kene W202 C-Class 2 06-29-2004 10:37 AM
E320 - dash vent control lamps Guest (MBNZ) W124 E,CE,D,TD Class 1 06-02-2002 06:15 PM
