airmatic valve problem - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 09-19-2008, 04:31 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: w220 s500, w140 s500, w210 e430
i have a 2000 s500 and i have a problem with the airmatic. the valve block above the pump doesnt seem to open to pump the shocks, i have a dis multiplexer and i activated the pump manually and it works fine the problem is that the valve block above the bump doesnt seem to be opening to let the air through to the shocks, anyone here an airmatic expert would have any advice. im getting it towed to a mercedes specialist(independent shhop) just would like to hear some feedback from anyone who might know what the problem it. i also had a spare valve block laying around my garage i tried installing it but same problem( i dont know is that one was functional before either) any help will be greatly appreciated
ekBenz is offline   Reply With Quote
Old 09-19-2008, 05:18 AM   #2 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic, 1978 450SL "Christine"
It's not an unusual problem in the '00-'02 W220s. Because you ran the pump and still saw no pressurization of the struts, you are probably correct.
While you're at it, have your Airmatic relay checked - if it's Hella, you're probably OK. If not, have it replaced with a Hella relay. The relay isn't the source of the particular problem you describe, but will prevent another frequent Airmatic problem - failure of the relay, either causing the pump not to run - or worse, causing it to run excessively, burning it out.
Warren
2005 S500 4-Matic
with Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 09-19-2008, 08:17 AM   #3 (permalink)
yea i replaced the relay already just recently so thats all set. thank you for the feedback i guess ill just have to bring it to the shop and see what they can tell me
Old 09-25-2008, 09:30 PM   #4 (permalink)
benz_addict's Avatar
Date registered: Aug 2006
Vehicle: CL & E
keep us updated
E 4 3 0 - Stock
E 3 2 0
C L 5 5: 175mm pulley, 80mm TB, CM90 IC pump, upgraded aux H/E to another CL65 wheel well H/E with fan, mandrel bent 3" stainless steel full exhaust system, AFE filters, Eurocharged tune, SL63 paddle shifters, BRABUS lowering module, oil catch can, fan on -10°C earlier, SAI delete. Yes my supercharger is WHITE. 11.9 @ 118
benz_addict is offline   Reply With Quote
Old 01-20-2009, 08:07 AM   #5 (permalink)
Detcomm's Avatar
Date registered: Jan 2009
ekbenz, i know it has been awhile but can you please tell me what the dealer did to fix your valve block problem? what was the repair and what did it cost you?
thanks so much
Detcomm is offline   Reply With Quote
Bookmarks
airmatic suspension problem mcavs The Discount Tire Direct Tire, Wheel, Brake & Suspension 41 05-19-2013 01:29 AM
airmatic problem coully W220 S-Class 5 07-26-2008 07:43 AM
airmatic problem! inneed of help again coully W220 S-Class 5 05-15-2008 01:35 PM
A different Airmatic problem? Rlbol W220 S-Class 8 07-07-2007 12:26 PM
airmatic suspension problem mcavs W220 S-Class 0 05-03-2006 02:59 PM
