Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 09-05-2008, 01:41 PM   #1 (permalink)
ackee911's Avatar
Date registered: Apr 2008
Vehicle: Mercedes S500L W220 Gilera Runner 180sp BMW 323i SE E46 Suzuki GSX-R 600 K4
D2B ring
Was at my local independant mercedes specialist today and I asked him whether I could bypass my cd changer so at least my phone would work (since my changer is faulty).
He said all I need to do is put both ends of the fibre optic cable together at the cd changer end so the light signal could continue.
Is this true? Anybody know the part number of the the 'joint connector thingy'
Thanks
ackee911 is offline   Reply With Quote
Old 09-05-2008, 04:35 PM   #2 (permalink)
Date registered: Nov 2004
Vehicle: My Benz: 04 S430
Thanks
true
My04230k is offline   Reply With Quote
Old 09-07-2008, 08:28 AM   #3 (permalink)
ackee911's Avatar
True?
I just tried it and the telephone is still not working. Does the D2B ring need to be reset or re-programmed to not include the cd changer? How is this done?
Since CD changers are prone to stop working, I have installed my own aftermarket sound system but want the phone to work through COMAND. How can I do this?
Old 09-07-2008, 10:34 AM   #4 (permalink)
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Skylaw is our resident expert on these matters. He will probably be along soon...
Don't believe everything you think
www.kcmbca.org
Kansas City Mercedes-Benz car club
Jayhawk is offline   Reply With Quote
Old 09-07-2008, 01:10 PM   #5 (permalink)
True?
Okay, now you are complicating things..
YOu can;t mix and match components on your d2b network. The only way a faulty CD changer will cause another component not to work is if there is a break in the light.
Usually thats not the case..
IF you have aftermarket sound, then how are you using d2b components in the first place?
Old 09-07-2008, 05:06 PM   #6 (permalink)
ackee911's Avatar
The aftermarket sound is completely seperate from the D2B ring. I purchased a interface for the TV button which has three phono's (video, audio left and right). This is wired to a media player which I control via a remote control.
So the rest of the COMAND is completely standard. The CD changer is NOT working and I have no intention of getting a new one as my media player is 500GB and stores enough songs on there.
The PHONE is also not working, COMAND says NO PHONE.
The phone cradle and mobile phone works fine.
Now, the punchline: ALL I WANT IS FOR THE PHONE TO WORK WITH THE COMAND AND STEERING WHEEL CONTROLS.
The guy at the independant merc place says if I connect both ends of the fibre optic cable at the CD changer end, the ring will bypass the cd changer and the phone will work.
I have tried this and it is NOT working. Do I need to reset the ring? If so, HOW!
Is there nothing else I can buy to replace the current system so that:
1) I can keep the current aftermarket setup
2) My phone works with the COMAND and steering controls
(Reason being, the current mobile phone is an OLD Nokia 3110, I would like bluetooth)
Now off-subject:
I was considering switching to a widescreen COMAND which plays MP3's in the COMAND unit itself. As long as I could get a phone working with it, the steering controls AND the aux in (via TV button), I would be happy.
Will I need to change the dash and steering wheel for this to work? Or is it just not worth it.
And before anyone says just buy a new car, I don't want a new car-I like modifying and adding things. I'll post pictures up of my setup soon.
Old 09-07-2008, 08:41 PM   #7 (permalink)
detay's Avatar
Date registered: Jan 2008
Vehicle: S430 Blk&Blk Sport Pkg.
Comand has to be coded (programmed) with Star Diagnostic in order to see the phone in D2B ring.
detay is offline   Reply With Quote
Old 09-07-2008, 08:57 PM   #8 (permalink)
Gotcha..
Okay, then if your phone never worked, you must have it activated via star.
for understanding, what do you mean the cradle is working?
WHen the command says "NO Phone" it means that the phone is not programmed in the system. If there was a problem with the phone AND it was programmed, it would say "phone not ready".
Widescreen DVD command is MOST.Unless you have a 2003 version that was non dvd.Those are D2B but I'm not sure if it plays mp3's like the dvd MOST version does.
Old 09-08-2008, 01:00 PM   #9 (permalink)
ackee911's Avatar
Gotcha..
COMAND says phone initialising when I start the car, but then goes to NO PHONE. Does this still need to be re-programmed?
I know widescreen COMAND is MOST, but will the steering controls and dash work with a MOST system?
Old 09-08-2008, 10:13 PM   #10 (permalink)
This is not as simple as you think.
If you want to convert your car to MOST there are a few zillion things that have to be changed including all of your audio components a lot of wiring and thousands of dollars like $10K or something like that.. do a search about this here or the other benz forum you will find a good post about that.
I still think your issue has to do with incorrect programming. or set-up, or mix match components and little to do with the fact that you cd changer is shot.
Figuring Out the D2b Ring slkerx3 R170 SLK Class 2 06-11-2008 09:05 PM
Ear ring, nose ring, tooth….. Johney21 Off-Topic 9 12-20-2007 09:16 AM
MOST or D2B My04230k W215 CL Class 2 12-24-2006 01:32 PM
Ring Ring. Who is it? Mercedes! BrentG500 G-Class 37 05-31-2005 07:43 AM
MOST or D2B ?? vandewal W163 M-Class 0 06-25-2002 11:02 AM
