Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 09-05-2008, 10:22 AM   #11 (permalink)
Date registered: Aug 2007
Vehicle: 2000 S430
Originally Posted by rccmerc View Post
Try another key to start the car.
i think my spare may be broken, like it got stepped on after the cat knocked it on the floor in my office.
ok after diggin it out i'm not sure what happened :lol:
The secret to success, whether it's women or money, is knowing when to quit. I oughta know: I'm divorced and broke.
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind.
~Dr. Seuss
icwater is offline   Reply With Quote
Old 09-05-2008, 02:43 PM   #12 (permalink)
Vehicle: 2000 S430
tried lookin over all the fuses didnt see anything, tried the broken key, it opens doors but wont turn in the ignition which makes me think the other key is working or it wouldnt turn, no?
i had just given a guy a jump before this happened, could that have done anything?
Old 09-05-2008, 03:37 PM   #13 (permalink)
Nickolas's Avatar
Date registered: Sep 2007
Vehicle: w220/S430
Unfortunately, it could. I would say, that this is most likely to be the reason of trouble than what you coul do checking fuses. Also, I doubt that it is posssible to locate the problem via Internet - this is the case for computer diagnostic.
Speaking about car-key, mind, that each key has a limited amount of codes that allow to start the engine - this is the picularity of Mercedes security system. When the key is out of code combinations - it becomes useless.
So I advise anyone who has only one key to order one spare key at a dealer's office - just in case.
Nickolas is offline   Reply With Quote
Old 09-05-2008, 06:58 PM   #14 (permalink)
Vehicle: 2000 S430
this is odd, i cant shift the gears in any key position, according to this i should be able to
Old 09-05-2008, 09:20 PM   #15 (permalink)
comforta's Avatar
Date registered: Jun 2007
Vehicle: 2003 S500 4matic
Your initial post and this post seem to describe two different problems with your vehicle. 1) Your car will not start 2) You vehicle will not shift out of park. Would you clarify if you have both issues or just one of them.
2003 S500 4MATIC - No Modifications!
comforta is offline   Reply With Quote
Old 09-05-2008, 09:25 PM   #16 (permalink)
Vehicle: 2000 S430
well as the car would not start i was not compelled to shift it out of park , but as i kept trying things i ended up trying to shift out of park and could not, so yea i have both problems.
i'm thinking i triggered some security measure, but hell if i know how to fix it
Old 09-06-2008, 01:47 AM   #17 (permalink)
~BANNED~
How old is your battery?
Do you have a volt meter to check to make sure it is good?
You might of killed the battery when jumping the other car. Also, you are mighty
brave jumping another car with a W220
Anyway check the battery, because these cars do some really weird shit when they are electrically underpowered.
rccmerc is offline   Reply With Quote
Old 09-06-2008, 09:04 AM   #18 (permalink)
Vehicle: 2000 S430
it's brand new the jump literally took 20 seconds
Old 09-06-2008, 10:57 AM   #19 (permalink)
~BANNED~
Ok, do you have volt meter and can you tell me what the new battery is putting out?
Also check to make sure the terminal connections to the battery are tight and not oxidized.
Old 09-06-2008, 11:03 AM   #20 (permalink)
Vehicle: 2000 S430
i do not unfortunately, but the battery terminals are spotless and everything seems to be getting plenty of power
Should I give up now and start checking the Obituaries for Classmates? Digmenow Off-Topic 8 07-07-2008 05:44 AM
unplugged the fuses and now car won't turn over ShannonRawls W220 S-Class 1 04-02-2008 04:52 PM
Car running a bit hot, also i want to know about relays and fuses found in the engine milosz87 W201 190E, D-Class 19 08-14-2007 01:49 AM
Barrel Fuses vs. MB Strip Fuses 94Wagenmeister W201 190E, D-Class 0 09-25-2006 07:09 PM
car won't start rfaquino W202 C-Class 9 07-05-2004 06:31 AM
