Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 09-03-2008, 04:35 PM   #1 (permalink)
Unhappy w220 airmatic woes. HELP Please
Hi guys, my 2000 S430 has another problem with its airmatic on her front driver side. Last year I fixed the front passenger side which cost me $2,100 and change when I took it to a "trusty" mechanic. I have little to no funds this time around and I'd like to know if any of you guys know of any online links to where I can buy the suspension parts and online do-it-yourself catalog myself and fix it over a 5 day period in my driveway. As it sits the car is on its face and is not driveable, i'd have to tow it to the mechanic which will cost more than if I fix it with my brother. I just need to know which parts to get for the front driver side strut or airbag, and tools to fix it. Any and all input would be greatly appreciated! Thanks
klexgs is offline   Reply With Quote
Old 09-04-2008, 08:35 AM   #2 (permalink)
Date registered: Jul 2008
The strut and air bag are all one piece (purchased together). You paid way to much for the first fix. I paid 3200 for both to be replaced and have some other minor stuff fixed. The struts are only $1100 OEM Volvo Volkswagen BMW Mercedes Parts
daily is offline   Reply With Quote
Old 09-04-2008, 12:50 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
that sounds like an ABC strut ("hydrophenumatic")
OliverK is offline   Reply With Quote
Old 09-04-2008, 01:13 PM   #4 (permalink)
Thanks alot, and how about a replacement for the cracking rubber seal at the top of the strut that is the culprit of the problem. Is there a metal seal replacement that goes in place of the old cracking rubber seal where a strut tower brace would go? I've searched ebay for tools and found a W220 Airmatic Strut Seal Remover Repair Tool for almost $160. Do you guys have any pictorial diagrams on the fixing of the front struts? Thanks for the responses.
Old 09-07-2008, 06:47 AM   #5 (permalink)
Date registered: Apr 2007
Vehicle: s320cdi 2000 / C180k
I think this is for yours ..
Êàòàëîã
(Note this site only looks to work with microsoft IE and not with firefox )
here's the main link..
??????? ????????? MB. ????? ??????.
Please let me know how you get on...
billyohh is offline   Reply With Quote
Old 09-07-2008, 10:42 AM   #6 (permalink)
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
My dealer replaced both front struts for a little over $300. BTW: Our cars do not have ABC, they have Airmatic suspensions.
Don't believe everything you think
www.kcmbca.org
Kansas City Mercedes-Benz car club
Jayhawk is offline   Reply With Quote
Old 09-07-2008, 12:12 PM   #7 (permalink)
thanks alot billyohh for the site, coincidentally I found that site about three days ago. Do you know if each strut has its own air pump. I'm trying to fix it myself the cheapest way and want to buy parts separately. How many parts make up the front driver side and how many steps are there to successfully replace the air pump and /or strut? Thanks so much for your replies guys!!
Old 09-07-2008, 12:29 PM   #8 (permalink)
Jayhawk's Avatar
You'd better find out exactly what is broken before you start throwing expensive parts at it. Strut kits are $71 apiece and dealer labor to replace is a little over $200, and from what I understand you will require special tools and knowledge to do the job yourself. An air pump will add about $500, but you had better know what you are doing. The culprit usually just a relay on the pump that goes bad and causes it to run constantly, and fail. There are a number of threads here on this subject. You should at least do a search before launching into a project like that.
Old 09-08-2008, 09:42 AM   #9 (permalink)
I had a similar problem a few years ago and after lots of research and asking I decided to let my MB dealer sort it. I found it was not just a case or replacing the part which requires some special tools but it also needs to be calibrated afterwards and if this is not done then you may have running problems ( however – with hindsight I’m not sure if this was true)
You will also find a lot of chat about the relay. This is something that is known to MB and they should be replacing this unit every time it has the 'B' service. (It’s on the B service workshop check list). If your car has not been serviced by MB then check this out and make sure you do get it replaced regularly.
However - The thing that really put me off in the end were the reports of cars that just suddenly dropped while being driven and the tyre running into the body work. As my wife also drives the cars with the kids in I decided the risk was too great for me. I know this could happen at anything and but for the extra cost involved I decided to let a professional do the job. ( Once I got the car back I not had another problem with the airmatic ).
I think if you do the research, have all the tools and are competent with a spanner then go ahead. If you have any doubts then step back and have a think.. The cost to fix any damage that you may cause could end up more than the car is worth - or just think of the damage to you.
Old 09-08-2008, 10:13 AM   #10 (permalink)
Jayhawk's Avatar
I have never heard of the car dropping while being driven... Where'd you hear that?
new question about w220 airmatic koray W220 S-Class 10 05-14-2008 02:52 PM
S CLASS AIRMATIC WOES (Yes Again!!!) tgmnewry W220 S-Class 9 11-01-2007 05:38 AM
W220 S500 Lo Km AIRMATIC CAR Item number: 290166178213 on eBay jorghenry W220 S-Class 0 09-30-2007 06:29 PM
'00 W220 Airmatic repair advice finntexan W220 S-Class 3 02-22-2007 05:45 AM
1999 w220 s500 airmatic question for frank European_motors W220 S-Class 3 08-23-2005 11:39 AM
