04 S500 trunk won't opwn without metal key
My trunk won't open without using the metal key. The door trunk release light (red) is on when I open the trunk with the key.. Key FOB, trunk release on driver's door, trunk lid button next to trunk key opening do not work/open nor close the trunk, only the metal key works. Once I open the trunk with the key, I can move the key back to 12 o clock and remove the key, then close the trunk manually by pushing the lid down (gently) until I hear it latch but it doesn't close all the way down (assist) until I again, manually push it down the rest of the way (gently as opposed to slamming it). When I push any the following (no metal key inserted) key FOB, driver's door button, or the latch button next to the key slot, I can hear the latch attempt sound for about 5-10 seconds but the trunk does not unlatch and open. I have to get the metal key out to unlock it. So, can anyone tell me the best order of things to check starting with most obvious through the most likely "process of elimination" for an 04 S500 model? I like to tinker and figure things out for myself mainly for the satisfaction of having done it and secondly, for not having to go to the dealer due to cost of labor. My problem is that this is my only vehicle so I can't take things a part for a few days if they hamper my ability to drive the car to work everyday, hence, the most likely thing to try first/process of elimination since this most likely will take some time to chase down.
