» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
BenzWorld.org is the premier Mercedes Benz Forum on the internet. Registered Users do not see the above ads.
Old 07-19-2008, 02:29 PM   #1 (permalink)
Date registered: Jun 2005
S430 help needed
Thanks in advance for your help....I have a 2000 S430 that was rough idle and running poorly. I was going to change the mass air because i was sure thats wahat it was...The other day sitting in traffic it stalled for no apparent reason. It would spin over and over but not start...I naturally thought CPS...After getting it to the side of the road and checking fuses etc...It came back to life...I know still need mass air and CPS..I bought the mass air and it started and ran great...Went ahead and changed fuel filter also...Today I run down to the local parts house to order a CPS...Come outside and it turns over and over again...This time even letting it sit is no good....I attempt to check the fuses relays etc, but I pulled the purple ANTI TOW relay at the fuse box under the rear seat by mistake....when I replaced it and put the key in the ignition to try one more time it says REMOVE KEY! in the diagnostic screen....Now nothing works and the car will not even turn over. NO WINDOWS, ignition, basically nothing 12v but the radio....dash light illuminate with the door opening, but not the switch. I put the key in and the wheel begins to lower and then stops..and then its if everything is dead..I show 12.8 volts at the battery and the seats interior lights and panic on the remote still work..Doors will lock, unlock, etc..But no attempt at ignition..Any ideas....Thanks for reading this..I know its lengthy, but Ive been in a hot parking lot with her all day.
Darty411 is offline   Reply With Quote
Is it Possible From 03 s430 to 02 s430 Nav !!!!! Nazar2350 W220 S-Class 1 12-21-2007 04:53 PM
help s430 wheels into e320; parts needed? rgmenguito W210 E-Class 2 04-07-2007 06:56 PM
S430/S500 Custom wheel pic's needed. laynlow W220 S-Class 4 05-17-2006 05:09 AM
New Blue tooth phone in S430 info needed Groundpounder03 Audio & Telematics Forum 9 11-07-2005 02:59 PM
Wheel advice needed S430 w220 shooter The Discount Tire Direct Tire, Wheel, Brake & Suspension 9 09-08-2005 06:46 AM
