Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 07-14-2008, 12:39 PM   #1 (permalink)
gmund's Avatar
Date registered: Mar 2008
Vehicle: 2006 S430 4-Matic, Silver/Black
How to remove wood trim from rear door?
I have an annoying little buzzing coming from the rear driver side door and I've narrowed it down to the wood trim.
If I have someone push on it when it's buzzing it stops. As I drive and go over minor bumps the buzzing starts up again and pushing it consistently makes it stop.
How does this wood trim come off? Does it simply pry out or does the entire door panel need to be removed?
Thanks in advance!
Gmund
gmund is online now   Reply With Quote
Old 07-14-2008, 02:04 PM   #2 (permalink)
Date registered: Jan 2008
Vehicle: 2000 Mercedes S500 2002 Yamaha R6
it is held by 3 or 4 clips just pry it off starting from the front of the door, be careful you can break a plastic clips in the door
Ramunsa is offline   Reply With Quote
Old 07-15-2008, 12:27 AM   #3 (permalink)
Date registered: Sep 2006
The best way to pry it off is to use a wooden wedge. This will stop any damage. Don't use a screwdriver. An old style wooden clothespin works pretty good. Pry under the strip, not on top of it.
admany2 is offline   Reply With Quote
Old 07-15-2008, 07:07 PM   #4 (permalink)
gmund's Avatar
Thanks for the advice!
How to remove wood trim on door??? MaximRick W140 S-Class 24 04-02-2008 11:17 AM
how does one remove the wood trim on dash>>? jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 2 01-20-2008 04:26 PM
HOW TO REMOVE INTERIOR WOOD TRIM??? jorantes W163 M-Class 4 01-13-2008 07:02 PM
Completely remove wood trim? gptce W124 E,CE,D,TD Class 5 11-25-2004 07:25 AM
How to remove your wood trim around MCS?? ... and those Designo wood part #s :) Shimmy W163 M-Class 2 11-30-2001 12:14 PM
