Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 07-04-2008, 02:16 AM   #1 (permalink)
Date registered: Jun 2008
key wont turn , how to tow?
So my key wont turn today, now i want to tow it but since I can't put the gear in neutral what would be the best way to tow it?
thanks.
hillz718 is offline   Reply With Quote
Old 07-04-2008, 04:03 AM   #2 (permalink)
eric242340's Avatar
Date registered: Nov 2007
Vehicle: S320
thanks.
Use a tow truck that is capable of lifting the rear wheels and tow it with the front wheels still on the road. The steering is locked anyway so no problem with a rear end tow.
Why wont the key turn?
ERIC
eric242340 is offline   Reply With Quote
Old 07-04-2008, 05:52 AM   #3 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
UNLESS it's a 4-Matic. And, hope the steering is centered.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 07-04-2008, 06:40 AM   #4 (permalink)
eric242340's Avatar
Vehicle: S320
Point noted, i think we should wait for him to tell us why the key wont turn as it may not require towing at all
Old 07-04-2008, 06:48 AM   #5 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
all you need to do is remove the gearshift cover and manually put it into nuetral.
Streetglower is offline   Reply With Quote
Old 07-04-2008, 08:01 AM   #6 (permalink)
i am not sure why the key wont turn, the navi works, the key opens and closes the door the dash light turns on and car inside lights. When I try to turn the key it just wont turn. Could it be a fuse that went bad or something?
Old 07-04-2008, 08:15 AM   #7 (permalink)
How would I go about removing the gear shift cover etc.
thanks.
Old 07-04-2008, 12:03 PM   #8 (permalink)
jdwh7's Avatar
Date registered: Mar 2007
Vehicle: 2006 Mercedes S350
Send a message via AIM to jdwh7
maybe the wheel is locked.....try holding the steering wheel like pushing it to the right or left where is wont move but an inch and hold it there and try to turn the key, it might work then.
--->J.D.<---
2006 Mercedes S350
With Gateway 500 Hookup
jdwh7 is offline   Reply With Quote
Old 07-04-2008, 12:14 PM   #9 (permalink)
comforta's Avatar
Date registered: Jun 2007
Vehicle: 2003 S500 4matic
thanks.
Do not try this manuever. The s-class was built so that there is not a gear release available using this method. If the other suggestions are not working to release the gear CALL THE DEALER OR ANOTHER MECHANIC YOU TRUST!
2003 S500 4MATIC - No Modifications!
comforta is offline   Reply With Quote
Old 07-04-2008, 05:17 PM   #10 (permalink)
have you tried your second key? if the second key doesnt work, the eis is probably bad. if it starts the first key is bad.
Ignition key wont turn Docjay R170 SLK Class 6 07-01-2008 07:49 PM
Key gets stuck and wont turn. hillz718 W220 S-Class 2 06-25-2008 06:43 AM
key wont turn in ignition msarles1 W201 190E, D-Class 13 04-24-2008 09:34 PM
C240 key wont turn Nicolemarien General Mercedes-Benz 2 10-21-2006 01:59 PM
IGNITION KEY WONT TURN ETECHJOE W163 M-Class 2 08-25-2004 07:54 PM
