» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W220 S-Class
Old 12-28-2007, 10:43 AM   #1 (permalink)
spoons's Avatar
Date registered: Mar 2006
Vehicle: 2006 C230 Sedan
Send a message via Yahoo to spoons
Thumbs up 2000-2006 S-Class DIY Oil Change
I made a PDF file that shows step by step how to change your oil for a 2002 MB CLK430. The same procedure should work for an S430.
This procedure also works for all the S-class MB's only the amount of oil maybe different. Check owners manual for Oil Capacity.
http://www.benzworld.org/forums/w208...hange-clk.html
Brian Richardson
Jupiter, FL
2006 Mercedes Benz C230 with 6-speed manual
1997 Plymouth Prowler with Matching Trailer
2003 Mercedes Benz C230 Kompressor (Sold)
1993 Mitsubishi 3000GT VR-4 (sold)
spoons is offline   Reply With Quote
Old 12-28-2007, 11:12 AM   #2 (permalink)
Nice, Thanks!
rccmerc is offline   Reply With Quote
Old 12-28-2007, 09:14 PM   #3 (permalink)
II kings 920's Avatar
Date registered: Dec 2006
Vehicle: '00 S430
Yup, I have done two now on my S430, all oil changes should be DIY (if you want it done right for a reasonable cost), no reason not to DIY (unless it's not "your thing".) Thanks for the link, perhaps it will give others the inspiration to DIY.
Your oil extractor technique is interesting, efficient, and clean. I will consider using it but I use a Fumoto drain valve in all my cars. This still requires ramps, removal of the belly pan, a wide catch basin and quite a bit more labor.
My only question is does the suction technique do as good a job as draining re: pan deposits that may be better drawn out of the pan with drainage?
Very important: YOUR PIC SHOWS THE CORRECT FLEECE FILTER, PEOPLE, DO NOT MAKE THE MISTAKE OF BUYING THE CHEAPER PAPER FILTER.
II kings 920 is offline   Reply With Quote
Old 12-29-2007, 08:35 AM   #4 (permalink)
Date registered: Dec 2007
Vehicle: 2002 S500
Send a message via MSN to MisterCeeII
I have heard that MB trained factory techs use a suction device to drain the oil that way so I don't think that method will be a problem
MisterCeeII is offline   Reply With Quote
Old 12-29-2007, 03:29 PM   #5 (permalink)
Vehicle: '00 S430
Yeah, I figured so since the techs do it that way (they also forget to tighten lug nuts so you really can't use their techniques as a guide all the time.)
This technique is great for MB and BMWs with a topside filter. On other cars where I have to go under to get to the filter I will stick with my beloved Fumoto drain valve and flick the lever whilst I am under there taking off the filter.
Old 12-30-2007, 07:18 AM   #6 (permalink)
Date registered: Apr 2006
Vehicle: 2005 SL500, 2007 GL450, 2006 S430 4-Matic
Spoons - Thanks for the posting.
On my 2006 S430, the engine has a red filler plug without a dipstick. While technology is great, a dipstick is much more convenient.
PH1958
(Previous) 1997 Smoke Silver S320
2005 Brilliant Silver SL500
2006 Brilliant Silver S430 4-Matic
2007 Brilliant Silver GL450 4-Matic
ph1958 is offline   Reply With Quote
Old 12-31-2007, 08:39 PM   #7 (permalink)
Date registered: Sep 2006
Vehicle: 2002 S600 W220
Send a message via AIM to platt-deutsch
I use a pump and was curious as to how good it sucked the oil. After pumping it I pulled the plug and didnt get much more than a cup full so I am confident the suction method is great..
platt-deutsch is offline   Reply With Quote
Old 01-02-2008, 11:44 AM   #8 (permalink)
fkong777's Avatar
Date registered: Nov 2004
Vehicle: 02 S430 - 00 ML55 - 91 NSX
Send a message via Yahoo to fkong777
I used a pump and just to be sure I open the drain plug to see how much old oil is left. There was just droplets of oil left. Extractor do get close to all the oil out.
fkong777 is offline   Reply With Quote
Old 01-03-2008, 10:55 AM   #9 (permalink)
Vehicle: '00 S430
Sounds like a transmission plug, I can't imagine no oil dipstick, what is the world coming to. I guess you just have to depend on the electronics, I like an oil pressure guage but those are gone too.
Old 02-11-2008, 01:38 PM   #10 (permalink)
Date registered: Jan 2008
I read somewhere that the paper oil filters are okay for the MB. Why is the fleece so much better? I got two paper filter for the price of one fleece. I plan to use the second paper filter at half FSS interval which I think will be more effective than using a fleece oil filter for the whole FSS interval.
tilolite is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
theseus
DIY Oil Change on 2006 - 2007 C230 tpenfield W203 C-Class 13 09-20-2008 10:38 PM
DIY : Oil Change hangon W163 M-Class 44 09-19-2008 03:29 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 08:58 PM
DIY oil change Neb W202 C-Class 28 06-12-2008 06:18 PM
2006-2007 C-class DIY Oil Change spoons W203 C-Class 0 12-28-2007 10:33 AM
