HELP!! can i change my gas pedal 2000 s430
20K views 11 replies 7 participants last post by  wpimentel
I searched the forum for info on changing the gas pedal myself but didnt see anything. I have a 2000 s430 and was wondering if any of u gurus knew how to change the pedal instead of having to take it to the stealership. Any help would be greatly appreciated.
Thx
I didn't bookmark it, but someone recently posted information on changing the throttle controls (not the gas pedal itself) on either BenzWorld or MBWorld; a search (gas pedal, throttle) may get it for you. The post was within the past 2 weeks.
Good luck.
#3 ·
just buy the pedal and replace it. Make sure the keys and ignition are off/out. Simple procedure, no need for programming. I have a used pedal, complete assembly from an 04 S430 i will let you have it for $50 plus shipping! Let me know if you are interested!
Good Luck!
#5 ·
HELP! can I change my gas pedal 2000 s430
Thanx fellas. Ghogan600...do u know where the screw is located on the pedal? I looked down there but didnt see an screws visible and I really dont want to start poking around and mess up anything. Can u give me a little bit more details? Greatly appreciated.
#6 ·
There is a screw under a plastic circle cap, towards the bottom, but under the pedal.
There is a screw under a plastic circle cap, towards the bottom, but under the pedal.(in between the pedal and floor.) pry off cap and screw is there, disconnect two connectors,and replace with new one.
#8 ·
I am having O2 Heater Circuit Failure codes and misfires all over on my S600. New MAF and O2 sensors did not help. Is there a possibility the pedal potentiometer is the problem? There seems to be a lot of talk about replacing this item.
#9 ·
thanks for the info guys....
thanks for the info guys....ghogan600 - u saved me $100 bucks!
a mechanic that works for one of the dealerships out here was gonna charge me $100 for 7 mins of work...not this time...thanx again guys.
#11 ·
W220 Accelerater pedal assembly or module?
Hi. I am new to the forum. I sell MB for a living for the past 12 years and recently purchased a 2001 S430 with 103000 kilometres. I have the issue of no throttle when cold.Our shop forman found the subject code @time of trade in last week but said further diagnosis is necessary before I buy any parts .It is COLD here in Calgary now and our shop is overwhelmed and can't get my car in . Is there anyway to know if I should replace the module or the complete pedal assembly? Or should I wait?
