Schedule Maintenance 2003 S430 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-19-2007, 07:31 PM Thread Starter
Date registered: Nov 2006
Fellow Members,
Do any of you know what are the schedule maintenance for 2003 S Class ? What are the things I need to change for each schedule maintenance ?
My 2003 S430 just passed 50,000 miles . What work needs to be done, and what work should be done, as far as fluids, belts, hoses etc. ?
Thanks.
Ray
raymond123_68 is offline
post #2 of 6 (permalink) Old 03-20-2007, 04:43 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 255 Post(s)
The maintenance manuals for the '04 and later cars (also owner's manuals) are online on the MBUSA website, http://www.mbusa; register (free) as an owner, and log onto to the owner's online section. Select "Maintain My Benz." For more convenience on subsequent log-ins, your default vehicle will be shown and a choice of owner's manual, maintanance manual, or other things related to your specific car will be available.
The '04 will be similar to your '03, for immediate needs. If you enter your '03's info and request a maintenance manual in the owner's online section, you will be given a contact number to get one; or, you can try the dealer. Enter info as if you had a second car that's an '04, name it your default, and you'll be taken there.
Your car has a Flexible Service System, which has sensors and a computer to calculate a number of input variables, and sense contaminants in the oil.. It then makes adjustments to your service interval (usually between 10 and 13 thousand miles) and tells you whether "A"or "B" service is due next (and in how many miles, or days). See 01 S500 oil analysis report & FSS discrepancy - MBWorld.org Forums
Also, if you search the forum, you will find that others have posted the specific items to be checked at some service intervals, including what is done for "A" and "B" service.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 6 (permalink) Old 03-20-2007, 11:08 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Here is the FSS schedule for our cars:
A-Service First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
B-Service
First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
Don't believe everything you think
Jayhawk is offline
post #4 of 6 (permalink) Old 03-21-2007, 08:19 PM Thread Starter
Thank you very much for the detail explanation on schedule maintenance for S-Class.
Jayhawk who do you recommend in Kansas City area that will be able to do Service A and Service B ? Preferebaly not Benz dealer.
Thanks.
Raymond
post #5 of 6 (permalink) Old 03-21-2007, 08:43 PM
Jayhawk's Avatar
Thanks.
Raymond
Sorry, but Aristocrat Motors, an MB dealer, is by far the best possible place to get your car serviced. They have been selling and servicing my MBs since 1970, and I can't recommend them more highly. Their A Service is about $240 and the B is about $350, I believe. They do an Mobile 1 oil change and 27 point check for only $59.95. I usually have that done at 5k intervals between A and B Services. They have many other specials and give a 15% discount on all parts and labor if you are a member of MB Club of America. They are even having a free technical session for members next week where they will put the car up and do a drive covering all aspects of our cars. The service manager is even making ribs for lunch for us!
Aristocrat Motors Shawnee Mission Kansas
Jayhawk is offline
post #6 of 6 (permalink) Old 03-29-2007, 01:15 PM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 255 Post(s)
Thanks, Jayhawk. This seems to come up so often, now I have it bookmarked.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
    2001 ML430 Maintenance Schedule? dean1969 W163 M-Class 4 08-02-2006 10:51 AM
    Looking for '03-'06 E55 maintenance schedule and estimated costs superbikepics W211 E55 AMG, E63 AMG 7 03-17-2006 08:33 PM
    Schedule "C" maintenance BenzE500 W211 E-Class 2 01-31-2006 11:15 PM
    Maintenance RESET schedule Big D W163 M-Class 12 11-17-2005 07:58 AM
    New owner: What does the maintenance schedule look like for SLK230? Black98SLK230 R170 SLK-Class 4 12-10-2003 08:31 PM
